Thread: Salt system for in ground pool with liner.... Please help
Threaded View
  1. #2
    Largo, Florida
    Default Re: Salt system for in ground pool with liner.... Please help
    Salt definitely corrodes metals. I've got a SWCG pool, Although I've only owned it for 1 year, the pool (and salt system) are almost four years old now. I have a metal light ring and housing, the ring had some buildup on it (most likely calcium imo) but I recently acid washed it and it still looks shiny and brand new. Don't have any aluminum coping to compare with.
    I like my swcg system. I had to run the pool for a month or two when I first bought the house without it because the control board was broken. It lets me be lazy and skip the frequent addition of chlorine, but I do have to add acid pretty much weekly to keep the pH in check.
    The topic was just discussed in much detail in this thread: http://www.poolforum.com/pf2/showthr...n-out-of-favor You should probably give that a read.
    Salt MAY void your warranty if you've got one.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  3. Using Intex Salt System with larger pool
    By gilbertmsg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-10-2012, 01:06 PM
  4. Mustard Algae in salt system pool
    By karla in forum Dealing with Algae & Slime
    Last Post: 09-08-2011, 08:03 PM
