Results 1 to 10 of 12
Thread: Replacing liner with high water table
    Jul 2011
    Illinois
    Default Re: Replacing liner with high water table
    Thanks Waste.
    I think I understand what you're saying: Wait until the water gets near the bottom faceplate of the stairs, then raise the vacuum lines up a bit, and if I've sealed the liner good enough - the liner should pull into the area where the stairs extend out from the wall (hopefully the liner will stretch enough to be flush against the wall at the bottom corners of the stairs). I suppose I could heat the liner with a hair dryer if I have to, and manually force the corners in?
    Jeff
    Sounds like we're on the same page
    I would avoid heating the liner to get the faceplates on - with a 70*+ day and sun, the liner should be pliable enough to get the faceplates on. If you need a little more stretch, you can cut the center of the liner that you'll be removing from the steps (in other words, stretch it from the stair side NOT from the corners). Definitely have the bottom plate installed first!
    Please let me know if you have more questions about this!
  1. Pump set up for an inground pool install in a high water table
    By lWINK1479 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2012, 10:12 PM
  2. High water table-can I save my pool?
    By swamplady in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2011, 10:05 PM
  3. HIGH Water Table
    By patsfan139 in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2006, 02:40 PM
  4. Emptying water before replacing liner
    By CathyOh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 12:18 AM
  5. Replacing liner and water
    By brider18 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-20-2006, 04:21 PM
