Thread: Pool Re-plaster - any way to "save" water?
    Berwyn, PA
    Question Pool Re-plaster - any way to "save" water?
    Making plans for a re-plaster in a few weeks. Contractor anticipates dumping water into woods behind us (that's no problem), then we'd probably refill with 4-5 6,000 gallon deliveries, plus the garden hose, to be able to fill in less than 24 hours after plaster is done.
    Seems like a huge waste of water (32,000 gallons), let alone money. Does anyone successfully pump water to holding tank(s) and pump it back when done? Or is this just too much darn water?
    Thanks,
    --Stu
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    Largo, Florida
    Default Re: Pool Re-plaster - any way to "save" water?
    Do you have a 30,000 gallon holding tank available to use? I'd think that would be the biggest problem, coming up with a suitable tank.
    Jul 2011
    texas
    Zip Lock bags? (many)
    BigDave's Avatar
    A Wikipedia article sizes "LargeTank Trucks" (Semi type) as between 5,500 to 9,000 gallons. It may be possible (but I'd guess a bit pricey) to bring some of these in while your pool is resurfaced.
    Jul 2011
    Cleveland, Ohio
    I know of one gunite PB in my area who offers a bladder service. They bring in a tow motor to unload the bladder from thee truck and pump water into it as a temp storage solutions. After work is complete, they replenish pool. I would check with gunite PBs in your area. I hope this helps you.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. My new pool to open on 6/25...here is the "store's" water analysis.
    By Machster in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2012, 11:51 AM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
