Thread: Adding stabilizer
    Default Adding stabilizer
    Is it possible to dissolve stabilizer too fast? I put 7 lbs in two socks and had the kids "play with them" in front of the skimmers. It was all dissolved by the end of the afternoon. My CYA reading was at 20 and I was trying to get it to 60 per my SWG system recommendations. 8 days later I got a reading of 40 but my pool store said it was 20. They want me to add 7 more lbs. but I don't want to get it too high. They said I dissolved it too quickly and that I should have let it hang in front of the skimmer and dissolve on it's own. I have an 18x36 IG SWG pool with a vinyl liner and I'm having trouble keeping my chlorine level up.
    Default Re: Adding stabilizer
    Dissolved is dissolved. The speed at which it dissolves can't change the amount that is now in the water. What kind of kit are you testing with? If you are doing the disappearing black dot test, I'd trust your own reading. You are right in that you don't want it too high.
  1. How long to wait before adding more stabilizer?
    By DesertSwim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2012, 05:09 PM
  2. adding stabilizer with Kreepy Krawley connected to skimmer
    By Ella5 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-03-2011, 08:50 AM
  3. Open new pool - question about adding stabilizer
    By The Raddish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 12:49 PM
  4. Adding Stabilizer to adjust CYA
    By waltham41 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 02:52 PM
  5. Adding CYA (Stabilizer) My Way - Lesson Learned
    By PatL34 in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 07:23 PM
