Thread: Code Brown!
    Dec 2005
    Jupiter, Fl.
    Default Re: Code Brown!
    The best time to add CL is at night as there is no sun to break it down. Shock your pool based on the recommendations published on the forum and you should be fine. In fact, the CL that you already had in the pool probably did the job already.
    I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
    15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
    Jun 2011
    Thanks, Denny! I appreciate your info.
    I guess my question would have been better worded if I'd asked "do I need to bring the pool to shock level after this?" I couldn't see anything in the dark last night to add and test FC shock levels, but I do test daily and have been consistently within Ben's recommendations for FC on the Best Guess chart. It's going to be 102 today so it will be torture trying to keep the kids out of the pool if I have to bring it up to shock level today.
    Without getting graphic, the accident was mostly contained. I think I'm going to boost my FC up to a max level this morning and let the kids swim later in the day. Anybody have concerns about this plan?
    Jim
    Largo, Florida
    If it were my pool, I'd rather have the kids in with a little higher chlorine than take the risk of bacterial infection. If your CYA isn't very high then the high Cl level will be gone rather quickly due to the sunlight anyway.
