Thread: Pool test smackdown: Taylor K2006, OTO, Pinch-a-Penny, Pool Store
    Jul 2011
    Boca Raton, FL
    Default Re: Pool test smackdown: Taylor K2006, OTO, Pinch-a-Penny, Pool Store
    AnnaK,
    Thanks for the "clarity" of your answer. :-) I wasn't sure just how sensitive the drop testing process is. I guess it's pretty sensitive. Usually when I get to what I think is the last drop, because it looks pretty clear already, I'll add one more drop of the reagent, and then it gets noticeably more white. To paraphrase Horton, A trace is a trace, no matter how small.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Lehigh Valley, PA
    All the way to infinity, yeah. But we don't need that sort of precision. When it doesn't get any more colorless you subtract all the drops you added to see if it would and then use that number in your calculation.
    Clear?
    Jul 2011
    Boca Raton, FL
    Very clear!
    One question, though: If I add another drop to see if it gets clear (during the FC test) -- and it doesn't get any more clear, because it's clear and colorless already -- does that extra drop of reagent goof-up the subsequent test for CC? I'm thinking it wouldn't matter, but I really don't know that for sure.
