PH Question
Pool is 95% full (just below skimmer) and have not added any chemicals yet. (will start adding bleach today to bring chlorine levels up) and will add CYA as soon as I can backwash pump and begin pump operations. We did test the Ph today and it was above 8.0 .. I read where CYA will lower the Ph, so should I allow the CYA to act before I decide to add any Muriatic acid to lower the Ph.
I purchased a test kit from a pool store, which had their label on it, but all of the drop vials are labeled Taylor and it looks identical to the Taylor 2006 kit.
So... My question is simply... Do I need to wait to see if the CYA lowers the Ph before I add any muriatic acid?
Thanks....
- You may not post replies
- You may not edit your posts
Forum Rules
