Re: red algae
test strips are NOT precise for water balancing. Get yourself a good test kit (recommended Taylor K-2006) to help prevent such things happening again and also to save you money on chemical additions! "Parameters in the middle of spec" are not a valid test results in terms of water balance. PPM readings with enough precision to be useful are. Strips do not have the precision (for example TA readings with a 40 ppm jump between color blocks are pretty much useless but are what strips give you. A drop based kit is 10 ppm which gives you valid information!)
IF you have pitting in a plaster pool then your water balance has been off (either pH too low, calcium way too low or TA way to low or a combination of the above.) Strips cannot test for calcium hardness at all, they test total hardness which does you no good. Therefore it is IMPOSSIBLE to achieve proper water balance for a plaster pool using strips.
A good test kit is a whole lot cheaper than replastering ( or even acid washing) a pool!
