Re: Best method for cleaning debris from bottom of a spa
kelemvor
Yeah, if you don't have a "cleaner port" you can just plug a hose into the skimmer and then the other end of the hose onto the vacuum head. If you don't mind getting in you could probably just use the hose, but the head lets you use a pole and stay dry while you vacuum.
the only port I have in the pool is the one for the pressure cleaner. For the vacuum you obviously want suction, correct?
where do you recommend picking one up like the vacuum you posted?
25,000 gallon Concrete/Plaster Pool with a D.E. Filter. K-2006 Test kit. Pool Forum Rocks!
