Thread: Another Algae Fight - Am I doing this right?
    Default Re: Another Algae Fight - Am I doing this right?
    Hi, thanks for responding. I am using the Taylor K-2006 and we have the Hayward sand filter.
    TA too low? I thought TA needed to be somewhere around 120? We're at 260ppm right now.
    The FC is now over 25ppm and we're holding there. Need to get more testing reagent. I will use the dilution method and try to find out what the real CYA is.
    This site is so utterly useful, in the past 4 days I've learned so much!
    9000K Fiberglass/Hayward sand filter
    Using Taylor K-2006
    OOPS! My bad. Meant to say TA is too HIGH. I went back and made the correction in my previous post. Sorry 'bout that but thanks for letting me know so I could fix it!
    Add a bit to your signature line ----- size of pump if you know it and also the fact that you have a K-2006 kit. Thx!
    OK, we've been holding at 25ppm for about a day and a half now. Water is getting clearer - hurrah! I guess we should hold another day at these levels? PH is now 7.4.
    Thanks again for your help!
    Using Taylor K-2006
    Still there, even clearer tonight. I do notice there are some orange stains on the steps and sides. Metal? To hit with Citric Acid? Leave alone? Not even sure how to test for that.
    Using Taylor K-2006
