Results 1 to 10 of 17
Thread: Levels of Pool
    Jul 2011
    El Paso, Texas
    Default Re: Levels of Pool
    Watermom,
    Yesterday I made the mistake of buying CYA that was liquid I forgot that I had to get granular CYA so I went and bought that today. Do I follow the instructions on the bucket or do I follow the instructions on putting some of the CYA in a sock and having it desolved by itself. The intructions tell me to disolve it in hot water and pour it in the skimmer. Is that what I should do?
    Thank You,
    Oscar
    Since you are fighting algae and will be backwashing frequently most likely, you don't want to put it in the skimmer or else you'll just throw it out with the backwash water. Use the sock method.
    Jul 2011
    El Paso, Texas
    Backwashing, Hmm I haven't been doing that? When should I do that? And am I supposed to change DE and all that when I backwash? See I told you i'm new at this. Don't really knwo what i should be doing.
    Thank You,
    Oscar
    I'm assuming you have a DE filter. You should backwash it when your filter pressure rises 8-10 psi over the "clean" pressure, or when you notice reduced flow from your returns. The backwash process will wash the DE out, so you'll have to add more...I'll let the DE filter people advise you on how much DE to add.
    Last edited by Watermom; 07-30-2011 at 07:13 AM. Reason: change 'pro ess' to 'process'
