Thread: Foam bottom with sand cove
    scottfly is offline ** No working email address ** scottfly 0
    Default Foam bottom with sand cove
    Just bought a above ground pool. I was wondering if it is possible to put down 2" of sand, 3/4 in foam and still use a sand cove.
    Thanks in advance
    fullhouse is offline ** No working email address ** fullhouse 0
    Lawton,Ok
    Default Re: Foam bottom with sand cove
    you can use sand for the cove or the prefab foam cove either one. we used to install a lot of above ground pools. the sand works really well.
    New Orleans, LA
    If you are installing foam (i.e. Gladon Happy Bottom), it will defeat the purpose of the foam to put a sand cove on top of it. The purpose of the Happy Bottom is to create a smooth bottom and adding sand on top of the foam wouldn't make sense.
    You can more info on foam cove at: www.gladon.com
    Josh
