Results 1 to 10 of 10
Thread: SWCG clogging
    Jul 2011
    South East Texas
    Default SWCG clogging
    Thank for all the help so far But
    24' round above ground pool 4 ' deep
    inyex 8110 swcg
    inyex 633 pump installed 21' hayward sand filter
    TC 3.0
    TA 200
    CH 350
    PH 7.2
    saline 3700
    CYA 0 ADDED 2LBS STABLIZER
    The generator clogges up every 2 to 3 days any sugestions ???
    im using a taylor 2005 test kit,
    Default Re: SWCG clogging
    Quote Originally Posted by alexthedog View Post
    TA 200
    CH 350
    I kind of highlighted the problem! How did your calcium and alkalinity get so high?
    Do this:
    #1 - Test your fill water -- is the calcium and alk that high in the fill?
    #2 - If your fill water is from a well, does it have metal (iron, manganese) in it?
    #3 - Are you using cal hypo 'shock'?
    You'll need to lower your TA, but if your fill water is low in TA and calcium, it might be better to do a partial water replacement, so your calcium will also be lowered.
    Jul 2011
    South East Texas
    thats the water from the well !!
    don't know about the metal content but i get it tested.
    the pool is clear and clean i guess we can forget the SWCG and just use Bleach ?
    probably for now, that would be best.
    Are you saying that your test results above are for your well water, not your pool water?
    Scottsdale, Arizona
    What do you mean by clogging ? How do you clear it once it clogs ?
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    Jul 2011
    South East Texas
    Quote Originally Posted by PoolDoc View Post
    yes/no the pool was filled from the well 1st of the month test was taken from the pool
    i have dropped the ta some by Aerating and acid
    SWCG clogging: it gets, i assume calcium build up between the plates. soak it in vinger over night and it cleans up.
    we only use bleach to control the Chlorine and muratic acid to control the ph nothing else has been added other than
    stablizer the water is still clear and clean, if their is not a way to reduce the hardness of the my water then is there a chlorine gen that will work in these conditions ???
    Jul 2010
    Largo, Florida
    I've seen posts on other forums where folks say they've used a submersible pump and pumping the pool water through a water softener to do it. My fill water goes through a water softener as all the water in my house does. I believe water softeners work by replacing calcium ions with sodium ions; so it probably would increase your salt level some.
    Ok.
    Turn the SWCG unit(s) off and chlorinate manually till your TA is 100 or below and your pH is below 7.6.
    Then, retest all values. It is possible to lower calcium via a process called lime softening. But you'll end up with a cloudy pool to clean up, and it's probably not necessary. By doing things the way I say, you can begin swimming right away.
