Results 1 to 10 of 21
Thread: Also have cloudy water (with a story)
    Palm Beach, Florida
    Default Re: Also have cloudy water (with a story)
    Quote Originally Posted by KurtV
    What levels are you keeping your chlorine and pH at?
    Todays numbers are
    CL 1.5
    PH 7.6
    TA 220
    Mandeville, LA, USA.
    According to Ben's alkalinity lowering procedures, you need to keep the pH at or below 7.2 while you're aerating. Aerating at your current pH of 7.6 probably isn't going to do much for you.
    mbar's Avatar
    Ashland, PA
    Your chlorine is still way too low, with a cya of 50 - 100 you need to bring it up to at least 10 ppms. If you want to keep it at shock to kill any remaining algae you have to bring it up to 20. This is "Ben's best guess chart
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    You will continue to have problems with algae if your don't keep your chlorine levels high enough for the amount of cya in your water.
    Northeast PA
  1. Cloudy Water - A Chemical Story
    By pigbat in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2012, 12:11 AM
  2. A touching and inspirational story.
    By Spensar in forum General Interest
    Last Post: 10-04-2006, 11:13 PM
  3. Another Baquacil to BBB story!!
    By amblush in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-02-2006, 01:36 PM
  4. Lowering ALK success story
    By GTakacs in forum Dealing with Alkalinity and Calcium
    Last Post: 07-31-2006, 02:13 PM
  5. Success Story!!!
    By bballdoc in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-25-2006, 09:55 PM
