Results 11 to 16 of 16
Thread: New Pool & Starting From Scratch!
    Default Re: New Pool & Starting From Scratch!
    And, baking soda can also go into the skimmer if you need to raise the alk. Again, slowly.
    Post a current set of testing results when you try out your new kit!
    Jul 2011
    St. Louis area
    Thanks for all the great help!! So I guess the Chlorinator is pretty well obsolete with the BBB Method, would it be alright to simply bypass it (take it out completely) & skip an xtra hose & run directly back to the filter?
    You could do that, or you could just let it stay empty and open the flow up all the way...
    The inline chlorinators do have their uses, but the key is to know HOW to use it without getting yourself into trouble. They are great for adding a low amount of chlorine, consistently, or for use during vacations to ensure that chlorine is being added to the pool. When my CYA gets a little low, especially if the temp is hot like it is now (air temp 106 so far, and it's only 1:00--yesterday we got to 110), I'll turn mine on and set it at 2 (on 1-5 scale) so that it's constantly feeding a little chlorine into the water to supplement the bleach additions. And when people go on vacation, they can be a good way to prevent coming back to green water. It's just that they're not to be depended on for sole chlorination method. So...if you don't have a flow restriction problem with it, I'd just leave it connected and empty, turning the flow rate up, in case you need it again in future seasons.
    Jul 2011
    St. Louis area
    Great advice, never thought ahead to when we might be gone for a while. Getting used to using the Taylor test kit, alittle overwhelming to start, but after doin it a few times it is a snap. Are you in the desert west? How hot does your water get in those temps & do you try to cool it down & how?
    I'm actually in the Northwest corner of Louisiana. This time of year my pool temp averages around 92-ish if left alone, but this summer has been much hotter and much more dry than usual-- as far as rain goes, we've only had a few sprinkles here and there, but it's been more than 2 months since the last real rain shower. So the air temps this last couple of weeks have been between 105-110, and yesterday was our 32nd day in a row over 100 degrees. Water temp 96, and that's with me running the hose in to top it off from city water for approximately 10 minutes every couple of days.
    As far as cooling goes, I sometimes run my pump during the night instead of during the day with a fountain attached, and that has a small cooling effect, depending on the humidity level. The only really effective way to cool it, though, is just to run the water on the slide while the kids are in--which is basically refilling from tap water. It can substantially drop the temp of the pool over a 2 hour swim period.
    Finally posting pictures (trying to work out a better way to handle this in 2012)
    Above-ground pool installation, with excavation issues:
  1. Starting from scratch (new water)
    By jilted in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-09-2013, 07:50 AM
  2. Starting from scratch - leveling ground
    By tebbert in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2012, 11:40 PM
  3. starting old pool
    By csc138 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-26-2012, 03:44 PM
  4. Starting from Scratch
    By anixon7 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2012, 03:50 PM
  5. Starting the pool process
    By hop6868 in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2011, 02:45 PM
