Thread: higher ph ?
    BigDave's Avatar
    Default Re: higher ph ?
    I'm glad your water is clear - I wish we could use our pool!
    The water treatment regimen described here is more like a feedback loop than a fixed recipie. Test your water on a regular basis then (if it's off) adjust to bring it back to where you want it. This method automatically compensates for changes in bather load, sunlight, heat, city water, etc. as you base your water treatment on measurements of your water.
    So... you add more bleach... not because you added city water but because your FC is lower than you want it. You add acid... not because of city water but because you pH reads high.
    I would make sure the pool is well circulated so you're not seeing a sampling error - maybe take a couple more readings from different parts of the pool.
    I agree that it seems strange that one inch of makeup water should throw you off but... that's what you measure.
    BTW, as I understand it, some city water systems are sanitized with chloramines which could cause high chlorine consumption. Did you find CC in your makeup water? Also the polyquat may cause chlorine consumption.
    May 2011
    kentucky
    i did take another ph reading and in another part of pool its still high but not as high as far as what is needed to get back i just wonder if it could be that i have my return more upward as i did 2 weeks ago i that case i was trying to get more water displacement and ripples effect instead of really no surface water movement in the lower setting i do run my pump on low all the time but since the water is and has stay crystale clear i will run more test later before i do anything its worked all this way dont know why it would change will get back with ya when i do another compleate test this evening, thx
