Results 1 to 10 of 14
Thread: Air is getting into my filter
    Honesdale PA
    Default Re: Air is getting into my filter
    I suggested silicone SEAL for the joint. Use the grease for the gaskets and O-rings. The seal is the caulking stuff. Just squish it around with your fingers. It starts to cure in 15 minutes or so.
    May 2011
    I put on a silicone seal (GE Silicone I) and the system has been greatly improved. Unfortunately, there is still some air getting into the filter. Is there a product or something that I can use to put around the joints to find other air leaks?
    Honesdale PA
    I don't know of anything to put around joints for finding leaks but one thing I've used is a stethescope without the diaphram. Use the open ended hose to get right at the joints. Works in tight places and really helps when you're listening for very localized noises.
    BTW...I looked at Home Depot for that grease and found two types, one says for ceramic seals also but I have no idea what the difference is in the two types. Got the stuff for ceramic and it seems like the right stuff so we'll see. Price is good too.
