Results 11 to 20 of 21
Thread: Fiberglass pool badly stained
    duraleigh Guest
    Default
    Whoa, Guys, you've misread his posts (not that I've ever done that in my life )
    The "pool" side of his exchanger is stainless steel...not copper. the "boiler" side is copper and it never touches pool water.
    Secondly, I'm a little mixed up. Using muriatic to clean up an acid caused stain doesn't make sense to me. I'm missing something but I don't know what.
    Off the subject, but muriatic is quite good at removing green masonry.....it's effectiveness diminishes as the masonry cures.
    Dave S.
    Default
    Quote Originally Posted by duraleigh
    Yes but he stated that he found the source of the staining , corroded galvanized pipes which means the stains were iron--the brown stain commenly known as "rust" and he replaced them with pvc (the pipes, not the stains!)
    The stain was caused by iron, not acid.
    Chemistry 101 here(it won't be pretty!)....Ferric oxide (rust) is FE2O3 (sorry no subscripts) which means the iron is in it's trivalent form (+++ charge) which is not soluable. HCl will convert the iron to it's bivalent form (++ charge) which IS soluable and the iron goes back into solution in the water as an ion FE++. This is the way all those metal treatments and stain removers basically work on metal. They don't get rid of them they just put them into solution again ready to drop out when you least expect it. If you have ever needed to use one and the water in the pool has not been changed there is a very real possibility that you will continue to need to use them based on the chemistry of what they actually do.
    Now to answer his questions. Since it has been determined that the HCL wont hurt the fiberglass pool and he intends to drain it that is probably the best way to get rid of the metals since he can rinse it afterward and drain to waste again. As far as treating the fill water, there are filters designed to remove iron specifically. If the levels are high that might be the best course.
    Dave S.
    Hope that makes everything clear
    duraleigh Guest
    Default
    Mark,
    This thread has become as convoluted as any post I've seen lately. I'm going to drop out with these thoughts.
    I don't think it has been determined that acid will not harm your fibreglas. It probably won't, but nothing in this thread promises that.
    Secondly, I would be very careful draining that pool. Fibreglas pools are designed to be kept full and draining one would, IMHO, jeopardize the structural integrity of your pool.
    Dave S.
    Default
    Quote Originally Posted by alohafiberglasspools
    First, the staining you see is a symptom of a much more expensive problem - corrosion of your copper heat exchanger.
    but . . .
    Quote Originally Posted by hoogie
    Last year I noticed that below the water line was becoming stained and couldn't figure out why. Tried metal out, jack's magic and a couple of other products with no results. Fast forward to now, pool is drained down about 1/3 and the staining is really bad, about the color of oak from the water line down. Figured I'd try some muriatic acid on a test area and it worked great for bringing it almost back to white. Gave the test area a good rinse when I was done.
    Michelle, acid does not usually remove copper stains from surfaces. Copper stains are black or green-to-blue, not "oak" color.
    Also, there are NO metal control products that are "removers". Proper use of some of them, IN CONJUNCTION with filtration, can sometimes 'stain' the filter, instead of the pool.
    If you choose to address chemical issues, please be careful to post based on your own field experience, rather than what you've been taught in a sales meeting. Many of the things that everybody in the pool knows to be true . . . aren't actually true. So, if you don't know something to be a fact from your own experience, as a service tech or a chemist or a manufacturing engineer, please don't post it as if it's true. Instead, report it as "many in the pool industry think . . . " whatever it was you wanted to state.
    We'd welcome any genuine expert knowledge you have . . . such as specific information about your company's products, or about FG pools generally, especially if you also know ways to solve those problems. "Poolsean" does this very well with salt products, including his own.
    But, please avoid offering generic solutions that someone in your company believes in, unless you know for a fact that these solutions are valid ones. Using a liquid metal control product, like ProTeam's "Metal Magic" will not, all by itself, solve problems with metal staining. And the HEDP based "Metal Magic" will do virtually nothing to solve problems with the iron stains that are Hoogie's problem. Nor, as far as I know, will Haviland's product, which is called "Stain Elimitor" (their spelling, not mine!), not "Metal Magic".
    Also, please note that I've added the required ID signature to your profile, so that any future posts will be properly identified, as required by the Forum TOS.
    Thanks,
    Ben
    Metal Magic (MSDS showing HEDP content attached):
    hoogie is offline ** No working email address ** hoogie 0
    Default Re: Fiberglass pool badly stained
    Thanks all for the advice. Some good stuff in there.
    I've been waiting until I had some info to pass on but unfortunately just looking for more advice.
    I finally got in touch with someone at the pool manufacturer who had somewhat of a clue. Can't drain it or I void my warranty. They recommended proteam metal magic and said they would ship me some. Been waiting 3 weeks now, calling every couple of days and hearing excuse after excuse of why it didn't ship yet. I'm skeptical that it will work anyway. I've probably spent $300 bucks or so in the last year for metal something or others that did nothing but take the green color out of my wallet.
    I read with interest about vitamin c. I took a tablet that I had, rubbed it on a spot for 30 seconds or so and the spot was nice and white after. Looks like it might work.
    I also read about adding muriatic acid to the water to bring the ph real low to dissolve the stains then add a metal remover to capture and filter it out. Unfortunately no details other than read the bottle. The bottle of course doesn't say "If your a moron and have badly stained your pool add this amount" Anyone heard of using that?
    I know I can get muriatic acid locally but not bulk vitamin c. I'd have to wipe out the vitamin section from every walmart for a 20 mile radius.
    Anyone heard of the muriatic acid route before?
    Thanks for all the thoughts and advice,
    Mark
  6. #16
    Hanford,CA
    hoogie, There is a link to an online supplier of bulk ascorbic acid (vitamin C) on the first page of this thread.
  7. #17
    mbar's Avatar
    Ashland, PA
    Here is another link in case you want to get 5 lb.:
    http://www.msm-msm.com/store/agora.c...scorbic%20Acid
    You bring your ph down, and lower your chlorine (the ascorbic acid will be used up by the chlorine) Just pour the ascorbic acid down the walls of the pool as you walk around. Put the filter on circulate, dump in enough metal sequesterant for the size of your pool and let it circulate till you see all the stains magically disappear! It doesn't take long. Then put your filter back to filter and keep it on 24/7. After 24 - 48 hours you can start to SLOWLY bring up your chlorine level. If you have a sand or DE filter you can put a chlorine puck in the skimmer, which will help to let the metal stain the filter instead of the pool. Youwill also have to bring up your ph level. After a stain treatment it is hard to keep the ph and chlorine up. Don't let the ph go higher than 7.2 for a while, and do not get your chlorine up to shock levels for at least 2 weeks. High ph and high chlorine will make any metals in your water percipitate back out to land on the pool. If you have any questions feel free to ask.
    Northeast PA
  8. #18
    Okay, here's an update. Happened to stop at a pool place today and they happened to have absorbic acid. Bought 10 lbs. I explained my dilemna to the pool guy there and he said to take 5 lbs, mix it in 5 gallons of water and use a mop and swab in onto the sides, bottom, steps, etc.. -- even though they are underwater. I did that, pain in the butt.
    I also took an extra step and sprinkled the last 5 lbs down the walls and onto the stairs and benches. Threw in a half a bottle of stain-x for metal, put the filter on recirculate, closed the cover and let it run for about 7 hours. Chlorine was nil and ph was about 6.0 when I started.
    Well, just opened the cover and it did NOTHING. Still brown as ever... I'm bummed. I'm seriously considering just draining it and spraying it with muriatic acid which I know takes the brown right off. Nasty stuff but it's turning into a money pit otherwise. Besides having brown walls, the water is cloudy and looks like crap and will probably take a bit of work and $$ to get it right after this. I'd seriously like to just start off fresh.
    So who can offer advice about draining my 11x24 fiberglass pool safely? Manufacturer told me not to as it voids the warranty.
    My yard is sloped so I know there's no standing water underneath it. Concrete deck all around so chance of cave in is minimal.
    I may rent some trucks jacks for support, gas mask of some type and then just spray away, wipe clean and refill it. Shouldn't be empty for more than 24 hours. BTW, the pool is enclosed so no elements to worry about either.
    Anyone have any other advice I should consider?
    And again, thanks everyone for the well thought out responses. I knew this was going to be tough one.
    Hoog
  9. #19
    mbar's Avatar
    Ashland, PA
    Smile Re: Fiberglass pool badly stained
    I really don't understand - if a vitamin C tablet worked, then the ascorbic acid should have worked. The low ph and no chlorine should have made this a snap. Are you sure it was ascorbic acid or oxcylic acid? I am really stumped. You can contact the pool company and ask them the best way to drain - they have to drain them when they have to fix cracks on the bottom. I have a friend who had to have this done, I will call her tomorrow and ask her how it was done. You must really be frustrated! I feel your pain. Keep the faith!!
    Northeast PA
  10. #20
    I'm finally stain free !!
    What I tried with the pool filled with water:
    Jack's magic
    Abscorbic acid
    Oxalic Acid
    Proteam Metal Magic
    Various metal stain removing agents
    Scrubbing
    Vitamin c in a sock
    Abscorbic acid was the most promising but it only lightened the stains a bit even after 20 lbs in a 7000 gallon pool.
    What finally worked for me:
    Drained pool
    Sprayed sides and bottom with a 1 to 1 mix of muriatic acid/water.
    Tougher areas got straight muriatic acid.
    Rinse pool, drained whatever water was left.
    Refilled pool and used a metal remover, sorry can't remember the brand but was used as a precaution.
    Muriatic acid is nasty stuff and even with protective clothing on I got a few burns on my skin. 1 to 1 mix didn't smell that bad but the straight stuff had a gagging smell once applied and if it weren't for it being a good windy day when I did it, I'd probably be dead.
    Not suggesting that anyone else drain their pool but for me after probably $600 in metal removers, scrubbing, mopping stuff on under water, etc. draining and spraying was a last resort and it worked beautifully. My pool and water look cleaner and brighter than ever. If I ever run into this problem again I'll be draining and spraying in an instant. It took one day from start to being full of clean water again.
    Thanks everyone for all the suggestions and support.
    Hoog
  1. Pristine Blue stained my pool and I want to switch to BBB /Chlorine
    By efxs25 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2013, 06:41 PM
  2. First pool, water is clear but fiberglass is stained and lots of scale
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-15-2012, 11:14 PM
  3. Pool is clear finally, Now the liner is stained.
    By Lawrosa in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-20-2011, 10:46 AM
  4. Pool pavers faded badly - Clean and seal advice Please
    By bell7272 in forum In-Ground Pool Construction and Repair
    Last Post: 07-31-2007, 06:38 AM
