Quote Originally Posted by duraleigh
Whoa, Guys, you've misread his posts (not that I've ever done that in my life )
The "pool" side of his exchanger is stainless steel...not copper. the "boiler" side is copper and it never touches pool water.
Yes but he stated that he found the source of the staining , corroded galvanized pipes which means the stains were iron--the brown stain commenly known as "rust" and he replaced them with pvc (the pipes, not the stains!)
Secondly, I'm a little mixed up. Using muriatic to clean up an acid caused stain doesn't make sense to me. I'm missing something but I don't know what.
The stain was caused by iron, not acid.
Chemistry 101 here(it won't be pretty!)....Ferric oxide (rust) is FE2O3 (sorry no subscripts) which means the iron is in it's trivalent form (+++ charge) which is not soluable. HCl will convert the iron to it's bivalent form (++ charge) which IS soluable and the iron goes back into solution in the water as an ion FE++. This is the way all those metal treatments and stain removers basically work on metal. They don't get rid of them they just put them into solution again ready to drop out when you least expect it. If you have ever needed to use one and the water in the pool has not been changed there is a very real possibility that you will continue to need to use them based on the chemistry of what they actually do.
Now to answer his questions. Since it has been determined that the HCL wont hurt the fiberglass pool and he intends to drain it that is probably the best way to get rid of the metals since he can rinse it afterward and drain to waste again. As far as treating the fill water, there are filters designed to remove iron specifically. If the levels are high that might be the best course.
Dave S.
Hope that makes everything clear
