Hi, Mark,
Interesting problem. I will be using a heat exchanger this Spring, as well. I'll pay careful attention to the metal issue.
I'd get an opinion from a Fibreglas pool manufacturer about draining. Perhaps there's a way you can do a 90% drain and be a little safer. I wouldn't do it at all 'til I got a consensus from the fibreglas folks.![]()
Ditto advice on muriatic to clean fibreglas. Good idea, just make sure it won't eat your pool![]()
Not sure I understand your concern about future metal. If the galvanized was the source, and you eliminated it, why do you believe you'll still have metal content when you refill with new water?
Dave S.
