Results 1 to 10 of 21
Thread: Fiberglass pool badly stained
    duraleigh Guest
    Default
    Hi, Mark,
    There's not too many fibreglas owners on the forum here so you may have to be patient. (I'm not one)
    Did you use PVC on both the boiler and pool side of your exchanger? If so, what temp is your boiler water coming into the exchanger? I'm thinking I'll probably use brass and PEX on the hot side and PVC on the pool side.
    Since the metal precipitated out onto your fibreglas and you have eliminated the source, I don't think you'll have any further problems
    Is your exchanger copper or stainless? If it's copper (on the inside), faulty pH can eat up the copper pipes pretty quickly. Stainless is pretty bullet proof but can still have some fittings that are just black iron that can lead to issues like you've experienced.
    Dave S.
    hoogie is offline ** No working email address ** hoogie 0
    Default
    Hi Dave,
    Boilder side is copper going in and out of the exchanger. Water temp I think is about 190. Pool water connections going through the heat exchanger have been my greatest source of difficulty and leaking. Sched 40, expands and contracts too much and eventually the teflon tape fails and it starts to drip. Galvanized pipe worked great for leaking but dismal for pool staining, a lesson learned. Shed 80 pvc loaded with teflon tape has worked out pretty well so far.
    My exchanger is all stainless, works great but wish I went a little larger, too much hot water exiting the exchanger back to the boiler so I believe larger exchanger would have transferred more heat. Shouldn't complain though, I can raise the pool temp about 1.5 degrees per hour with the current exchanger.
    Mark
    Default
    hoogie,
    I have a 16k gallon fiberglass pool. I have never drained it completely since the manufacturer told me not to as it will void the lifetime structural warranty. While building the pool, this concerned me so much I kept inquired about draining further. I found out fiberglass pools can in fact be drained if:
    1. There isn’t any ground water under the pool. Mine has an access lid (identical to the skimmer) with a 12” plastic pipe that extends to the bottom of the deep end. Builder said this was for pumping out/inspecting ground water in case the pool needed to be drained.
    2. The walls MUST be braced. One of the workers told me they use “spacer jacks” like the ones used in the back of a tractor trailer to brace loads. I’m not exactly sure how often/how many braces must be used. This is apparently to prevent stress on the walls from the settling ground around the pool.
    As duraleigh suggested, I’d get a manufactures advice. Keep pressing them. If the original is no help, try C&W pools in Joelton, TN (615) 256-7329. They have been making fiberglass pools for 40+ years. I’m sure they'll tell you don’t do it but it may be worth a try.
    Have you tried using ascorbic acid? It has worked wonders for me in the past. It is available several ways. I generally use a product called Stain Free however I have noticed several other products out there. Anything that says ascorbic acid (a.k.a. vitam C) should do the trick. It is around $40 for a dosage that treats my $16k gallons and I get it at the local pool store. I end up treating once a season to remove metal stains. Definitely try this before you drain your pool. I found out about it here on the forum after spending $100 on Jack’s Crap to no avail. It worked perfectly on the first treatment. Good luck.
    Default
    Thanks David, I'll check into that. It would be mint if I didn't have to drain it.
    Mark
    Plymouth, MA 02360
    Cool Link to Ascorbic Acid in Bulk.
    http://www.chemistrystore.com/Ascorbic_Acid.htm
    The difference between food grade and not is that when they get it in the box form from the manufacturer it is food grade. Once they re-package it in smaller quantities, it can't be sold as food grade. I found this out because last summer they ran out of the non-foodgrade containers, and he called me to ask if I would take the bigger box.
    It is the exact same product as the pool store "Ascorbix" and the like and much cheaper. However, Acorbic acid does not fix your problem, it only helps you return the stain to "a solution". A sequestering agent, which you will have to buy at the Pool Store will "hold it there".
    Read the Pool Docs Thread regarding Metals and Staining. All pools are different. And I have not found one pool store or pool maintenance company here in Southeastern Mass. that even remotely understands the concepts of this Forum.
    I have a 35,000 gallon vinyl lined pool with a heater.My metal comes from my fill water, which is a well. The fill water has a very low PH {5.5}and High Mangenese. I have a very hard time maintaining the PH at 7.0 in my pool.
    I chlorinate my pool with nothing but sodium hydro chloride, using a liquimate feeder in a 5 gallon gerry can, and 1/2 to 1 gallon of 12.5 per night.
    I never allow my stabilizer level to go over 40.
    Filter is 6 hours on, 6 hours off. The liquimate adds just enough SHC to keep me chlorinated . This formula keeps me stain free until the squestering agent wears off, or my ph rises to 7.4, at which point the metal falls of solution and stains my liner. Then I add the acorbic acid, it magically disappears, and the circle remains unbroken.
    Good luck to pool owners with wells.
