Thread: Going back to Freshwater
    May 2010
    Houston
    Default Going back to Freshwater
    Just wondering, how hard or what should I be aware of if I converter from Saltwater back to semi freshwater? My SW Cell needs replacement and I thought about just keeping the pool full of water and using chlorine tabs.
    Lehigh Valley, PA
    Default Re: Going back to Freshwater
    Think about it. Chlorine is chlorine, whether it comes from a SWCG, a bottle, or tabs. initially, you'll have salty water left over but that'll get diluted in time. With the tabs you have the added challenge of possibly overshooting the CYA level. With plain bleach or liquid chlorine, all you have is chlorine. The results are pretty much the same: water sanitized by chlorine.
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    but the salt will be in the water forever ,unless you drain and refill
    Having salt in the water is not a problem--there are quite a few users on this forum that don't use SWCGs that added the salt anyway because they like the feel of the water.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    I agree. I add salt to my pool but don't have a SWCG. The water is fabulous. Does not impact anything about chem balance that I can tell.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
    Caledon, Ontario, Canada.
    It will get diluted over time. I have to add one to two bags of salt to our pool each spring just to keep the levels up for the generator.
    The biggest changes will be in the first couple of years. Five years from now I think you'd have trouble tasting the salt.
    16x32 vinyl; SWCG, DE filter, Intelliflo pump,
    solar heat ( to over 90 deg for the wife)
  1. finally back
    By horsesaremylife1030 in forum General Interest
    Last Post: 06-07-2011, 03:28 PM
  2. I'm back, baby, I'm back !!!!!
    By pool newby in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-24-2008, 03:41 PM
  3. I'm Back!
    By CarlD in forum General Interest
    Last Post: 09-24-2006, 12:28 PM
  4. I'm back.....
    By ellenicol in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2006, 08:07 PM
