The Quantab salt strips (not the quick read type) are good and accurate provided that you store and remove the strips properly, and the strips are not swapped with another bottle (as the strips are calculated to the range on that specific bottle). Make sure your hands are dry before removing a strip. Store the bottle out of direct sunlight.
Why is your AutoPilot reading differently from the test strip? Most likely the strip is bad...just a drop of water in the bottle will contaminate the rest of the bottle. May as well toss it out.
If you do a TEST POOL PILOT, the displayed Cell Amps and Volts will indicate if your salt is actually low. As salt levels fall, the voltage increases. Depending on the model cell, there is an acceptable voltage range. The amperage should hold steady and is based on the Cell Power setting.
Hope this helps.
