Alkalinity
I bought a house three years ago with an older in-ground pool so I am a relative newcomer. I consistantly have a problem keeping the ALK in the 80-120 PPM range. I recently bought a Taylor K-2006 tester so I could get reliable numbers. My pool ALK normally wants to stay in the 140 - 200 PPM range; since my fill water is from a well I decided to test the water from the tap (TC 0.0; pH 7.4; ALK 325; calcium hardness 180 and CYA 0.0) my pool water as tested is FC 24.0 (because of an algea bloom) CC 4.0, TC 28.0; pH 7.8; ALK 140; CH 380; CYA 100. The CYA got high because I was using a lot of stabilized shock and it will only come down from dilution. My question is since the fill water ALK is so high going into the pool should I keep trying to keep it in the 80-120 PPM range. The pool water temp is above 90 degrees.
Bobgard
- You may not post replies
- You may not edit your posts
Forum Rules
