I ran the vacuum to waste last night. I could see a big color difference from where I vacuumed to where it still had junk and could see the color in the clear pump lines change to brown when I was sucking up the junk so it was really bad. I needed to refill about 5" of water after that was done so I also added one bottle of bleach to make sure chlorine levels were plenty high. This morning the water is a nice blue color, but still cloudy. I took a sample in to check CYA levels again and they said its now at 10 probably due to the changing out of so much water. I have some stabilized tables left over. Can I use them to bring the CYA level up some and supplement the bleach for chlorine or will that throw things off. I don't want to undo whats been done so far. Thanks so much for all the help so far.
Jamie
Your TA level is not high enough to cause concern about rusting. Also, it is normal to have a temporary rise in pH when using bleach, since the pH of bleach is 13! However, as the bleach is "used up", the pH goes back down--so don't adjust your pH just to keep up with the bleach.
