Re: New to the forum - Trying to get a handle on pool chemistry
You can absolutely use the tablets to help raise the CYA levels--just keep an eye on your pH and make sure it doesn't get too low--trichlor tabs are acidic and can drive pH downward. It's fine to use the tabs and the bleach at the same time in the pool--after all, it's all chlorine when it gets in the water. Just don't let the bleach and tabs come into direct contact with each other before they're in the pool.
