Results 1 to 10 of 18
Thread: Help a CANUCK
    Aug 2011
    Oakville, Ontario CANADA
    Default Re: Help a CANUCK
    Can you believe that after the 12 liters of 6% bleach, OTO being as dark as a pale ale, I woke up this am to a yellow line at the bottom of the pool?
    Ben – do I release the hounds and add another batch of bleach. My PH seems to be in the right area.
    Suggestions?
    Thank you,
    Christian
    Are you sure it isn't pollen? Raise the chlorine level back up this evening when the sun is off the pool. An hour later, test the chlorine. You can force your kit to go higher with a dilution method explained here: Testing Without a Good Kit
    Test again in the morning within two hours of sunrise. If you lose no more than 1ppm of chlorine overnight, then it most likely is not algae.
    Aug 2011
    Good question on the pollen versus algea.
    Pool looks better but still not great. Chlorine is high. I will get water tested again and report back. You guys aren't kidding about pool stores, they have no clue. I am fortunate to have 6 pool stores within a 10 km radius and the'ry all trying to sell me the entire inventory.
    Aug 2011
    Latest numbers:
    Free Chlorine: =>10 ppm - They cant measure > 10 ppm
    Total Chlorine: 10 ppm - They cant measure > 10 ppm
    Combine Chlorine: 0.0 ppm
    pH: 7.8 ppm
    Hardness: 170 ppm
    Alkalinity (w/ stabilizer correction): 60 ppm
    Cyanuric Acid: 35 ppm
    Pool looking better but still needs help.
    Use your OTO kit and test it yourself using the dilution method from post#12. That way you'll be able to go higher than 10ppm with the testing.
    See what happens overnight like I explained above. I have a feeling it may not be algae, especially with a CC reading of 0.
    7.8 is the outside of the recommended pH range. You test it with your kit and see what you get. (BTW -- What is the highest that your pH tester will read?)
    If you lose no more than 1ppm of chlorine from sundown tonight until within 2 hours of sunrise tomorrow, it is unlikely that it is algae.
    Run the pump 24/7 while you are trying to clear the pool.
    SalemCastles Guest
    Aug 2011
    Water looking much better. Tried dilution method with a three-to-one but it's still high. i'm thinking about 12 ppm.
    The pool is looking amazing though. My highest PH measurement goes to 8.4.
    Thanks everyone,
    Christian
