Thread: Hayward Vari-Flo Multiport Vale Replacement question
    Jul 2011
    Southeast
    Default Hayward Vari-Flo Multiport Valve Replacement question
    Hey guys....and the hits keep coming...haha! Finally got my new pump/motor working properly and now my Multiport valve is worn out. The spring is shot and the gasket is gone, so I just bought a new top portion. I need to replace the spider gasket of course and have gotten various different advice on how to install the gasket. Seems that rubber cement is a popular standard when installing the new gasket but can someone tell me the correct steps and which side the cement needs to go on? Any help would be appreciated...Im ready for the repairs to be over......for a little while atleast!!!! Thanks guys!
    Randy
    Default Re: Hayward Vari-Flo Multiport Valve Replacement question
    Welcome to the Forum!
    Take a look at this thread for my take on gluing in wagon wheels
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    I agree with waste. Make sure to lube the gasket well and you should have no problem. One thought... always make sure to shut off the pump before moving the handle on the multiport valve. In addition... I was told at one point to always move the handle in the same direction when I change settings (I use clockwise). Not sure if that makes a difference, but my replaced gasket has been working with no leaks for years.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
    Jul 2011
    Southeast
    Thanks guys. I agree, I always shut off my pump before moving the valve and I also always go in the same direction. The replacement seemed to go well, I took alot of time and got the channels cleaned out and dried very well. I used the 3M product that Hayward reccommends to install the new gasket. I waited 24 hours before starting the pump back up. It seems to be operating smoothly. The one disappointment was that the "air sucking" noise is still present. I was told by a pool company employee that the noise was due to the extremely weak spring in my old valve letting water bypass the selected setting. The new valve I installed feels like new but the noise is still there and the water that I have been battling is STILL cloudy. For the life of me I can't get this water clear. Now it appears I am losing water from SOMEWHERE......ugh! I pulled the floor up and checked the plumbing under the pool house and it all appears dry. Maybe the skimmer seal?? Close to a bulldozer!
    Pool Owner Patience, please
    Try filling a bucket, mark the water line in the bucket, set it on a step - so the water is the same temp as the pool and mark the pool water level. Wait 12 - 24 hours and compare the water lost from the pool to the water lost from the bucket (the water missing from the bucket is evaporation) If the pool looses more than the bucket- you've got a leak and we'll help you narrow down where it's going.
