i have an inground pool and noticed after i filled it a few days ago that the liner had slipped out for about a 5 inch span. i played with it a bit in the hot afternoon sun to see if i can stretch it enough to get it up over the ridge and i'm pretty sure i can. last year i did a few spots..not quite as long with the pool full and it worked fine..the question i have is is there some kind of special tool to grab the liner to pull it up? last year, i tried to get screwdriver under the edge like with a bike tire but it didn't work so i used a pair of pliers to grab and pull..because of how much this chunk is out..it's a) a 2 man job i think..one to hold , other to tap in one of the plastic wedges..b) i tried a vice grip to pull and it seemed to work okay but boy, had to pull pretty good.
like i say, i think i can do it that way, but is there a tool or thoughts on what might make it easier to grab and pull over the top? i don't want to drain the pool after putting in 6,000 gallons of water!
