Thread: swim after muriatic acid
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default swim after muriatic acid
    After adding a gallon of liquid muriatic acid, how long should I wait before swimming?
    Default Re: swim after muriatic acid
    Assuming you put it into the return stream, I would wait at least two hours to make sure you don't get into "pockets" of concentrated acid. Also, I'd check your pH after a couple of hours to make sure it's still in the 7.0-7.8 range...
    Aug 2011
    Thanks for the info Janet, much appreciated.
    Just out of curiosity, how big is your pool? A gallon of acid at one time seems like a lot for most residential pools unless you are dealing with brand new plaster.
    Aug 2011
    indeed it is. I actually put in a quart. In my original post I mistakenly typed "gallon." Good catch.
