Results 1 to 10 of 16
Thread: Is a 33' round unstable?
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: Is a 33' round unstable?
    I've owned a 33' round with 54 inch pool walls for the last 5-6 years. It's never been unstable. The only problem we've had occurred this year with the jhook liner coming out around the coping in a small area. We have a small aluminum deck and fencing that goes completely around the pool. Part of the deck actually rests on the top rail of the pool . See my signature for a link to pictures.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Well the pool in question is a Sharkline and the depth is 54". Gwrace.....that looks amazing. Love your setup. I'm still leaning towards a 33', but it's also a difference of about $1000 compared to the 28' (extra water, install, electrical, etc). Looks worth it though.
    Aug 2011
    Massachusetts
    Not sure if I should open up a new thread for this but I don't want to be considered spamming so here goes. Can you tell me whether or not I'm getting a good deal?
    Sharkline 33' 54" depth pool -$3699 (pool only)
    Installation: $1300
    Then there's the "package". I'm not sure what I need or don't need, or will still be missing:
    25 gauge ultra or print liner beaded or overlap (Beaded looks nice, but I guess overlap is safer?)
    Filter choices: Hayward 200 lb S210T Sand Filter/ Hayward EC50 Earth Filter/ Hayward X Stream Filter (Leaning towards the sand since I'm a newbie)
    1.5 HP Hayward Motor & Pump (Good or overkill?)
    Then the rest are standard package deal things: A frame ladder, twist lock plug, winter plate for skimmer, thru wall skimmer, directional flow return? Skimmer Vac attachment, heavy duty filter hoses, telescopic pole, vacuum hose, vacuum head, hand skimmer, thermometer, test kit, filter sand or filter powder, deluxe platform for filter & sanitizer, winter cover, air pillows, winter plugs.
    Then chemicals: 4 bags of activator, 4 bags of 78% turbo shock, 10 lbs alkalinity up, tpp algacide, 4 lbs conditioner/stabilizer, prevail sanitizer cartridge, prevail automatic sanitize (chlorinator)
    They're charging me $1200 for this package. Is there anything I won't need, or should ask to substitute to give me some negotiating power?
    BigDave's Avatar
    Smile Re: Is a 33' round unstable?
    Price - I can't say - If you're happy with it, then great!
    Installation - does it include sand and block? How about electrical?
    Liner - Up to you, I think the beaded / J-Hook look nicer - safer, I don't know - sorry.
    Filter - 1.5 HP may be alot for a 21" sand filter - I too like sand. The advice I've seen here is larger filter, smaller pump. Too much pump can push crud right through a filter that's too small. The slower the water moves through the filter the cleaner it will be.
    You will need: a ladder ( do you need code - compliant self closing, latching? );skimmer and return; vac with hose, pole, and skimmer plate; hand skimmer; filter media; winterizing gear.
    Test Kit - Do yourself a big favor and buy the Taylor K2006 test kit (find links here on pool forum so forum gets a little cash to stay afloat).
    Chemicals - you don't need most of this list and it may cause you trouble with water quality. Read all about BBB on this forum and on PoolSoultions for, what we all agree is, a great way to maintain your pool.
    Cartridge Sanitizer - I don't know about prevail, but these "chlorine free" - "reduced chlorine" systems are unneccessary and could cause problems - refer to the BBB method - it works, you'll be happy, really.
    Good luck and Have Fun!
    BD's right,
    These extra tools to supposedly make your life simpler can make it much harder.
    An in-line chlorinator CAN be used with the B-B-B system but the key to B-B-B is regular testing and that won't change. In-lines use Tri-Chlor stabilized tablets and these add stabilizer (Cyanuric Acid, aka, CYA) to your water at 60% of the rate they add chlorine. That's good when you don't have any CYA, but bad when you have enough, and worse when you have MORE than enough. They also add acid, lots of it, so you'll find you'll need to add Borax constantly to raise pH levels. Still, early in the season, an in-line can help bring your CYA level up while maintaining a constant flow of chlorine. In the spring, I usually use the tablets in a floater to achieve the same goal, and watch the pH.
    Caveat: Do NOT drive yourself crazy using "Dual Acting" tablets, or ones that say "With Algaecide!". Chlorine IS an algaecide and they are adding copper, which you don't want.
    Chlorine reducing systems like Nature2 cost more to use than they save in chlorine. Never trust pool chemicals that don't say what they contain but use cute labels and vague references. Bleach is still the best chlorine and algaecide.
    (Note: Many pool stores sell Liquid Chlorine, frequently as "Liquid Shock". If it's 12.5% sodium Hypochlorite, it's nothing more than double-strength bleach--my preferred chlorine. If it's price per unit is less than double the unit price of bleach, it's a better deal than bleach because you use half as much. If it's more expensive than double the price of bleach, bleach is cheaper.)
    Aug 2011
    Massachusetts
    BD's right,
    Thanks Carl. Looks like you guys know how to save money. I'm already loving this forum!
    Aug 2011
    Massachusetts
    Dis-regard post #9, I was trying to quote the whole thing not just the first line, maybe it's a limitation on here? Anyway, I'll copy/paste instead so here goes....
    Sand-yes, block-not sure, what is block for?
    I like beaded, but overlap seems much less likely to ever come off.
    So, should I request a 1 HP pump instead of a 1.5? Is a 21" filter enough, or should I request a bigger filter?
    Yes, latching.
    Thanks, appreciate the recommendation.
    So, should I just tell them to keep all of those chemicals and buy my own?
    Cartridge Sanitizer - I don't know about prevail, but these "chlorine free" - "reduced chlorine" systems are unneccessary and could cause problems - refer to the BBB method - it works, you'll be happy, really. -
    I definitely will, but is this the same thing as a self chlorinator? Even though it's not listed, I remember the woman at the pool store showing me a self chlorinator that is part of the package. If these are one in the same, then what's the alternative? Those floaty pod chlorine things? Sorry I'm a total newbie. Trying to learn everything, but I'm on information overload right now. I haven't looked into the BBB method yet as I haven't gotten the pool yet, but I definitely will be looking into that method.
    Aug 2011
    Massachusetts
    Price - I can't say - If you're happy with it, then great! I find the price fair, and the pool to be of good quality.
    Thank you, and thank you for taking the time to respond.
