Results 1 to 10 of 16
Thread: Is a 33' round unstable?
    Default Re: Is a 33' round unstable?
    You can use a floater if you need to use tablets. That's what I do. No plumbing and they run $10 or less.
    BigDave's Avatar
    From what little I could find on the Internet regarding prevail sanitizer: I was wrong to assume it was a mineral type - chlorine free - reduced chlorine system (I hate being worng). It is , apparently, a system that delivers some (unknown) type of solid form chlorine in an "easy to use" - "recycleable" plastic cartridge. I couldn't determine what type of solid form chlorine comes in the carts - but - all (almost all) solid form chlorine comes with some built-in usage limit. For di-chlor and tri-chlor, it's CYA and rising CYA requires rising FC levels for effective sanitization and algea supression. Calcium hypochlorite use is limited by rising calcium hardness levels that can cause scaling or cloudiness.
    My general skepticism (and a casual understanding of the costs of packaging) leads me to surmize that whatever is in the carts costs more than the same chemical in a bucket. I would also guess that prevail is not widley distributed and that it's dealers enjoy a significant mark-up and a captive market.
    Please - learn about the BBB method so you can determine for your self what you need and what you don't. You will certainly need some of what they're incluing in the package - you'll certainly need stabilizer (aka conditioner, Cyanuric Acid) but what the (_ _ Double Hockey sticks) is activator?
