Drain & Fill for Algae?
Good Afternoon. I've been looking around in the forums, hoping to find the answers I need, because I'm sure they are there, and I hate to ask the same question that has probably been asked hundreds of times! The problem is I don't have the readings like others have, so can't share that information.
I recently had a sand filter change, first one since I bought the house seven years ago. I was assured that would fix my algae problem. It didn't. Now I'm being told that because my pool is over-stabilized, I will need to drain it at least half way and refill it. The only readings I have are what they told me when I took the water in to get tested:
Chlorine - 5
PH 7.6
Alkalinity 120
and Stabilizer is well over 100
Since I don't know what all the abbreviations are in the other posts, I don't know how to compare this to others' problems. I've always just tested chlorine and ph, and my kit shows them both within the color range they are supposed to be.
I'm feeling like a pretty ignorant pool owner, but this is the first time I've had any real issue with it. I hate to put out another couple hundred dollars on a water bill when I just did that for the new sand.
Thanks in advance for any help you can give!
