Thread: pad for pool equipment
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default pad for pool equipment
    I am going to replace my equipment (filter, pump, heater) this fall. I also will rebuild the concrete pad on which the equipment sits, because the pad is old, deteriorated and crumbling. I bought the house earlier this year, and the pool and equipment are 30 years old or so.
    My question is, is a concrete pad necessary? Are there other types of surfaces that I can put the filter, pump and heater on? Or does it require a concrete pad? Maybe this is a local building code question, but any insight would be appreciated. thanks in advance.
    Default Re: pad for pool equipment
    Hi and Welcome!
    I cannot answer about the heater but you certainly can put the pump and filter on concrete patio blocks. I have 18x18" patio blocks under my pump and filter.
  1. Pool Equipment
    By cforge in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2012, 10:14 PM
  2. Researching pool equipment
    By GatorWayne in forum In-Ground Pool Construction and Repair
    Last Post: 04-02-2012, 12:29 AM
  3. Help...freezing pool equipment!!!
    By poolboy69 in forum Pool Equipment & Operations
    Last Post: 02-05-2011, 06:16 PM
  4. Need the same equipment the pool guy has?
    By bkny1055 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-02-2009, 01:36 PM
  5. Pool equipment
    By nyjobz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 03:13 PM
