Thread: Drain Leak
    Aug 2011
    Orlando, Fl Greenville, NC
    Default Drain Leak
    I live in Orlando FL but am part owner of a hotel in Greenville NC. The spa has a fairly quick leak that is not effecting the pool. There are two drains but I do not know how many pipes going back to the pump. When it was first looked at there was sand in the spa, they did something to correct that. BUT, they say they will have to tear up the tiled floor to find the leak. From what I read on line they should be able to locate the leak thru the pipe and then be able to re-line the pipe. Question is since there a very few pool contractors in the area how do I find someone to repair the leak? Does re-lining the pipe work, make sense? Use a pool contractor, or a plumber? Any advice would be great.
    Ken
    Default Re: Drain Leak
    Hi Ken;
    I don't think there is any 'general' answer your question: only local ones. It doesn't really matter what someone, somewhere, can do . . . if no one in YOUR area can do it. Leak detection is tricky, and requires good tech AND good skills, along with a fair amount of luck.
    You might try looking up the phone of the SCP (South Central Pool) wholesaler in your area, call them, and ask who does leak detection in YOUR area. That's really the only relevant answer.
    Good luck.
  1. Suction side leak . . . Found in Pump Drain Plugs
    By TomC in forum Pool Equipment & Operations
    Last Post: 06-15-2012, 05:26 PM
  2. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  3. How far to let leak drain?
    By AndyT86 in forum In-Ground Pool Construction and Repair
    Last Post: 10-22-2006, 06:47 PM
  4. Possible drain leak or broken pipe?
    By Brillo724 in forum In-Ground Pool Construction and Repair
    Last Post: 09-09-2006, 08:04 PM
  5. Pool Drain or No Pool Drain (Skimmers vs. Jets)
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2006, 02:22 PM
