Thread: Hayward Ultra Vac Not Moving
    Default Hayward Ultra Vac Not Moving
    My Ultra Vac recently stopped moving - my suction is good and all of the consumables have been replaced. When it's on the bottom of the pool, the pods stop moving because it's being pulled on to the pool bottom and the force of the pods isn't enough to get it to move. I assume that this means that the internal gearing is bad, so I would like to replace all of the suspect parts.
    Is there a list of parts that I should replace to give it a full "tune-up"?
    Scottsdale, Arizona
    Default Re: Hayward Ultra Vac Not Moving
    If adjustable, reduce the amount of suction being sent to it. I've found if i give mine too much suction it moves in a jerky motion and some times stops.
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    I tried adjusting the amount of suction from full (well below the "max" line on the suction gauge) all the way down to about 25% (just above the "min" line). Regardless of where I set the suction, it won't move.
    The pods move fine when the unit is suspended in the water, but as soon it hits the bottom, the pods are barely able to move.
    I opened it up at lunch and saw that two of the rollers on the A-frame assembly had come (they were sitting in the pre-filter basket with all the ball bearings). I picked up an A-frame/turbine kit for $55 at the local pool store so we should be up and running this evening.
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Quote Originally Posted by matthewnadeau View Post
    Did it work?
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    May 2010
    I got the exact same problem at first then bought the kit and replaced the A frame and internal roller for $45 on amazon. it worked great for 1 day then now doing the same thing, just like you described. any advice???
  1. Hayward Ultra and the Skimmer Vacuum Plate
    By slater1182 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-21-2007, 02:36 AM
  2. Difference between Hayward Ultra and Navigator
    By wuptmor in forum Pool Cleaning: Manual or Automatic
    Last Post: 01-30-2007, 12:50 AM
  3. Hayward Ultra Vac is making me dizzy...
    By Phillbo in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-17-2006, 11:42 PM
  4. Barracuda, Kreepy vs. Hayward Ultra Vac or Navigator
    By Rural in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-10-2006, 09:33 PM
