Thread: Hayward Ultra Vac Not Moving
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default Re: Hayward Ultra Vac Not Moving
    Quote Originally Posted by matthewnadeau View Post
    I opened it up at lunch and saw that two of the rollers on the A-frame assembly had come (they were sitting in the pre-filter basket with all the ball bearings). I picked up an A-frame/turbine kit for $55 at the local pool store so we should be up and running this evening.
    Did it work?
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    May 2010
    I got the exact same problem at first then bought the kit and replaced the A frame and internal roller for $45 on amazon. it worked great for 1 day then now doing the same thing, just like you described. any advice???
