Results 1 to 8 of 8
Thread: Source for bottom sand?
    Dec 2005
    Royal Palm Beach, Florida, U.S..
    Default Source for bottom sand?
    Excuse my ignorance,but where does one go to find proper bottom sand for an AGP?
    Thanks,
    John
    Default Re: Source for bottom sand?
    Mason's sand is perfect. You can get it from any sand and gravel dealer/quarry. Color, of course, doesn't matter, but it comes in black, red, yellow and white. It's smooth, clean and even, and doesn't cost too much. You buy it by the yard, which, by definition, is a cube 1 yard on each side. But measures are never that exact. Still, one cubic yard will cover 9 square yards (9'x9') to a depth of 4".
    Dec 2005
    Thanks Carl.Would you happen to know the approximate amount of sand needed for a 30' AGP?And once this sand is leveled out, I'm assuming that the pressure exerted by the water is all that is needed to compact the sand,as opposed to doing any compacting before the pool is filled?
    John
    Aranon is offline Registered+ Thread Analyst Aranon 0
    Where I live its $27 a yard with a $40 delivery fee
    It depends on how deep the sand is. At a 4" depth, I'd get at least 10 yards. For 6", I'd get, naturally, half again as much.
    But I make NO guarantees. I'm estimating based on 4", on a 15' radius pool (30'), and that the sand yardage is exact.
    Ontario, Canada.
    The instructions that came with my 21' AG pool said to compact the sand.
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    you have to compact the sand otherwise you will have footprints, lumps etc. all over the place. it also helps if the sand is a bit damp prior to putting the liner in, it will help the sand not to move around as much.
    New Orleans, LA
    You should also shoot the site with a transit level to ensure that the pool area is level.
