Results 1 to 10 of 10
Thread: Just Getting Started here
    Default Re: Just Getting Started here
    Quote Originally Posted by les_garten View Post
    Hi,
    I'm looking for a reasonably priced outdoor capable probe that would turn on and off a Stenner dosing pump/MA Tank.
    Decent ORP/pH control systems are costly . . . and they still have all the problems I mentioned above. Cheaper units have additional problems. I think you may be looking for an "elephapottamus" -- a beast that doesn't exist.
    Ben
    Aug 2011
    PSL, FL
    OK,
    What problems are associated with the Hayward AquaRite pro system and the sense and dispense? I am not interested in ORP.
    Covered above, already. It's a pH / ORP system, with a SWCG and a conductivity probe. So, the list above applies, but with the additional complications of an external conductivity probe.
    BTW, you may not be interested in the ORP control, but it's bundled. As far as I know, the only pH only controllers will be marketed industrially, and not by the pool industry.
    Ben
    Aug 2011
    PSL, FL
    Ben
    Gotcha.
    I understand everything you said above. I've been looking into this for a while. I was trying to avoid a SWG with pH dosing features like Total Control or Aquarite Pro. Mostly because I didn't necessarily want to buy their SWG, and I didn't want both systems going dead at the same time (SWG and pH).
    My pH drift will drift up as far as I can tell. I live in FL, it rains a lot, I have a water feature, and I want to do SWG. I add acid, that's kinda what I do.
    I have a heater that I want to get rid of, so I can have a spot well away from any metal. I'm pretty set on the Stenner PUMP/Tank.
    I don't want to get into the Total control because of the cash outlay, so it looks like the only way to go is the AQ Pro.
    I looked at all the other controllers(Industrial/Instrument quality) and they are expensive, and some not made for outdoors.
    The Sense/Dispense uses the CAT Probe/Manifold setup.
    I've read quite a bit about this system and haven't found a lot of things to dissuade me. What are your thoughts on that system?
    I also was looking to see if there was a DIY system for Sense/Dispense that someone has done, but haven't found one yet.
    I think a neat idea would be a Linksys Router running Linux with a USB interface to a pH Sensor and a method to turn the pump on/off. Then I could watch it wirelessly inside the house.
    Les, this is about tinkering, not pools.
    There's a guy -- Richard Kinch -- who did TrueTex, who's been doing some sophisticated tinkering for more than 10 years, and recorded it here: http://www.truetex.com/poolcontrol.htm . He's even driving some of his control functions with Bash shell scripting.
    Check it out. It's more along the line of what you're looking for.
    Sincerely,
    Ben
    Aug 2011
    PSL, FL
    Sincerely,
    Ben
    Heh Yeah you're right!
    I had read that page, he lives close tome as well I think.
    Thanx!
