Bill,
Have your salt tested to see if it matches the displayed salt level. Your amperage is low, which may be caused by scaled cell (which you've already said it's clean), cold water temps (below 65 degrees), or low salt. If you add a bad of salt into the pool, at the deep end, your error display should go away, which can confirm the low salt condition.
If they are different, you'llneed to calibrate the salt display to your tested salt level.
