Thread: Salt system with small Easyset?
    Aug 2011
    Burlington On
    Default Salt system with small Easyset?
    I'd like some advice for setting up a SWCG with a small (10 or 12 foot) above ground pool. I found an Intex 8110 for a good price. Has anyone used this type successfully with a kiddie pool?
    Largo, Florida
    Default Re: Salt system with small Easyset?
    Does your pool have metal sides or anything else metal? If so, you'll need to be aware that going salt will likely void your warranty as salt corrodes metals pretty quickly. Other than that I think I read that intex uses some nonstandard plumbing (this mainly seems to come up when intex owners try to replace an intex pump or filter with a non intex one). If your pool isn't an intex pool you might have to buy or make some sort of adapters.
    Those intex swcg systems are REALLY inexpensive (I see them on various websites for about $200 new?). So much so that it brings to mind the old phrase about a deal being too good to be true... On the other hand there's really not a lot TO swcg's.. they use electrolysis to break down salt into chloride; no moving parts really. I've always thought they were overpriced myself.
    Aug 2011
    Burlington On
    Thanks Kelemvor
    My pool is the "bag of water" style, no metal. I think I'll probably have to do some pipe work for odd sizes. Oh well, the kids love it.
  1. New member w/ small Intex pool, looking at salt systems
    By Air_Cooled_Nut in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-21-2013, 07:53 AM
  2. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  3. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  4. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 05:37 PM
