Results 1 to 10 of 17
Thread: First time closer
    Aug 2011
    Lansing, MI
    Default First time closer
    I've been reading closing threads. .......A couple of questions for closing the pool for the first time here in MI. It's a used 21' AG. The pool came with a black "plastic" winter cover (has a copper wire running around outside through grommets and a single pool pillow. My questions are after draining below skimmer and return lines, do I leave the skimmer attached to the pool? I'm worried about taking it off and on and wearing the gaskets out by removal every year. Looked into the aquadoor, though it seems unnecessary if I plan on draining below the return right? My plan was to remove the "eyeball" of the return and leave the hole unplugged for winter water drainage. Do I remove the gasket at the return as well? ......Not sure I trust the pool pillow to hold the cover up all year as it seems like a cheap blow up. So, I like the idea of covering until leaves stop falling and removing the cover. Does this make sense? Anything I'm missing?
    Default Re: First time closer
    You do not need to remove the skimmer or the gaskets.
    As far as covering until leaves fall off and then removing cover, you can do that. Or, just don't cover it at all. I don't cover mine anymore.
    Aug 2011
    Lansing, MI
    Ok. thanks Watermom. I do have two huge black walnut trees that have nice little leaves that like to ride the wind into the pool. Everyday occurrence as we're starting to get cooler weather. Probably use the cover for sanity here shortly. Though the pool Rover vac works like a charm getting the ones that have sunk. Thanks, again. Andy
    Honesdale PA
    Ice does damage when it forms with no space for expansion. If you're concerned about getting a solid chunk of ice from melting and refreezing, rain, etc then just pack the skimmer with pool noodle foam. Cut up a noodle and pack some chunks in the skimmer. Can even whittle a piece down with a sharp blade and shove it in the skimmer pipe after you disconnect the hose. Can do the same with the return eyeball fitting. Use a relatively fresh noodle, one that isn't starting to deteriorate, or the white closed cell packing foam...eccofoam. Same as the noodle stuff.
    Jul 2011
    Bowmanville, Ontario, Canada
    ... Or, just don't cover it at all. I don't cover mine anymore.
    Watermom...could you elaborate on 'not covering for the winter'?
    (rationale, who, why, pros/cons, etc.)
    This seems like a major contravention to how us lemmings are doing things (or planning on doing things...I'm a 1st timer)...but this forum sure seems to do well banging their own drum...and I kinda like the beat so far!
    I see the point of using a 'winter' cover in the middle of a forest (kinda like Labpool's situation). However, I'm in the middle of a barren sardine subdivision. There's not a tree over three feet tall to be seen. I seem to remember an errant blade of grass in my skimmer last week...maybe. So, I'm now thinking I don't need a winter cover...I was just going to get one...because that's what's done by all the other pool owners I know. (I can imagine the ice would wreck my solar blanket.)
    I do kinda suppose there's a slight chance a maple leaf could sail in...from about 1000yards away...but I'll net that sucker out right quick, anyway.
    I'm not all read up on the whole 'closing' process, yet. I'm not actually planning to close until October, untill the temps get 10-ish. A fellow buddy of mine suggested the later to close and sooner to open = happier pool water. Kinda makes sense to me, since it means less warminsh/stagnant time for ickies to do their thing. I'll be bouncing ideas off the closing threads when the time comes...
    Thanks,
    5300 Gallon (15' x 52" composite & aluminum - AG)
    (Not Salt Water - Liquid Chlorine - Trying BBB...)
    Sta-Rite Mod3 60sqft DE Filter (with 8lbs charge) - Sta-Rite 2" Dyna-Wave Pump (<<< L-O-V-E )
    All 2" plumbing (except 3" suction line, modified skimmer) - Two 1.5" returns at 180degrees apart (skimmer return piped down to floor)
    "15' round 5.1K gal AG pool; ~10% liquid Chlorine; Sta-Rite Mod3 60sqft DE Filter DE filter; Sta-Rite 2"" Dyna-Wave Pump pump; 11hrs; Taylor K-2006
    'drops' FAS-DPD Chlorine, ; utility water; summer: ; winter: ; iPhone; PF:24"
    I do have trees in my yard near the pool -- in fact, one that hangs over part of the pool. So, I get a deluge of leaves. But, I just use my Polaris 65 to get them out. (I don't use that vac all that much during most of the swim season. It is good at getting leaves and twigs but not too good with dirt and dust. So, it gets used in the spring when all the 'helicopters' from the maple trees, etc., are falling in the pool and then in the fall when the leaves are falling, but the rest of the summer I use my "Wanda the Whale" vac or just vacuum manually.)
    My winter cover is a big pain. I used to always use it to keep the leaves out of the pool, but decided it just wasn't worth the hassle. So, the leaves fall in the pool, the Polaris 65 gets them out, and then the pool is fine for the winter. I do get some dust/dirt on the bottom but that is easily removed in the spring within a couple hours with the vac. The water stays clear.
    I just decided I didn't want to fool with it anymore, so quit using it several years ago. Al (Poconos) lives in northeast PA and he also does not cover his pool.
    You are right --- the later you can close and the earlier you can get open and get the equipment up and running so you can chlorinate, the less chance of algae.
    If you have any specific questions, let us know. (From what you wrote, I'd say you probably don't need a winter cover.)
    Jul 2011
    Ok. I get your point...and I understand winter covers can be a massive hassle. (the same guy who suggested late/early run times also laments about his winter cover...)
    So here's my final question on this (I thought about this one too late to add it to my post...)
    I'm supposing the foot, or so, of snow and ice that builds up just becomes spring opening re-fill inventory?
    Do you have any provision for overflow prevention? (like pipe in a length of backwash hose into a return so any extra rain/melt water can pour out and get taken away) or do you just let the skimmer overflow?
    -or-
    Are you up and running before the spring rains become an overflow problem (and still running after the fall rains stop)?
    Sponge,
    I've only closed pools in the Southeast, which is very different that your area.
    But, I do know it's common in severe weather areas to drain AG pools by 2/3, to avoid the sort of problems you are anticipating.
