Results 1 to 10 of 11
Thread: Sand Filter and Cartridge Filter Owners Please Advise
    Default Re: Sand Filter and Cartridge Filter Owners Please Advise
    if sized and maintained correctly
    . . . and that rarely happens on AG pools, especially, with AG pool sand filters.
    Undersized DE and cartridge filters still filter effectively, but just have very short (maybe, very very short) filter runs. Undersized sand filter do not filter effectively, and result in cloudy pools that won't clear up. Undersized or dirty filter cartridges, when coupled with high head (high pressure capable pumps, which include most inground pumps) can collapse, though this tends to be more of a problem on heavily used commercial pools (like the ones I've serviced) than on residential pools.
    So follow Ben's rule: If they recommend a certain size filter for a given pump, go up one size for IG pools and up two sizes for AGs. So, if they recommend a 150# sand filter, on an IG pool, get a 200#. On an AG pool get a 250# filter.
    (there are exceptions: My pool is technically AG, but so similar to an IG and uses an IG pump that I only went from the "recommended" 150# sand filter to a 200# sand filter with no problems as I wind up 9 years with it. But recently I did some new calculations and realized that I had no problems because my filter is just over the limit of an adequate filter for my setting. It's ALMOST too small, but "almost", as the saying goes, only counts if you are tossing horse shoes or hand grenades.)
    Actually, Carl, that wasn't quite how I meant it.
    What actually happens is that the 'recommended' filter size for, say a 20,000 gallon IG pool, is a 22" filter (at 15+ gpm/sft). But, due to some games the industry played with the NSF, the 'recommended' size for a 20K gal AG pool (at the 'rigged' standard of 25 gpm/sft) is about an 18" filter.
    But, what you NEED for either pool is a 24" filter, which gives you about 13 gpm/sft.
    I stand corrected...
  1. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 07:54 AM
  2. Sand Filter vs Cartridge Filter
    By dandelion in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-07-2012, 04:40 PM
  3. cartridge filter advise vacuum to waste
    By pberm1962 in forum Pool Equipment & Operations
    Last Post: 07-24-2011, 10:36 AM
  4. Sand filter over filter cartridge
    By wikid321 in forum Pool Equipment & Operations
    Last Post: 04-05-2011, 01:04 PM
  5. Sand to Cartridge Filter
    By PowerOut in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 08:28 PM
