Results 1 to 10 of 15
Thread: Searching for more about "Operating Swiming Pools at High PH"...
    Jul 2011
    Bowmanville, Ontario, Canada
    Question Searching for more about "Operating Swiming Pools at High PH"...
    Hi Eh,
    Ben has teased me with his page about running a pool at high PH. (Link removed by mod to speed up posting to forum) I've been searching the forum for more meat, but I can't find it.
    I'm especially interested in more about "shocking" (in the 'eighth element of easy PH control' paragraph).
    I'd love to join in on this one. I've finally Boraxed myself up to a nice pink 8-ish (on my K-2006)
    About 5 days ago...
    My initial runs were pretty textbook (from memory...lost my little log sheet):
    FC - off scale due to gallons of 4% bleach dumping during initial fill
    CC - 0
    CYA - working on it...
    PH - 7.5-ish
    TA - 100-ish
    Hardness - 100-ish
    I remember being around -0.4 on the little spinny dial calculator.
    Tonight:
    FC - 4.5
    CC - 0
    CYA - too scared to waste any more reagent ~300 grams confirmed dissolved was still <30 yesterday
    PH - 8-ish
    TA - has stayed 100-ish the whole time
    The temps have been cool here, there's been no pool action for a couple days.
    Minor note: I floatied a single tri-cholor puck, since the water was half full, at wide open. It's still pretty much there (really slow to dissolve). I don't 'plan' on always using Tri-Chlor...I just wanted to jump the CYA gun and try and keep some FC there while I plumbed everything up. (kept circulation with a submersible sump pump laying on it's side|). The floatie is still there, but I suspect it's effect is minimal. I'm going to pull it when the puck has dissolved.
    Anyway, back to the topic...
    Can I get in on this whole high PH operating methodology? I'm curious...and always appreciate an easier and likely? cheaper way to do things.
    Thanks!
    5300 Gallon (15' x 52" composite & aluminum - AG)
    (Not Salt Water - Liquid Chlorine - Trying BBB...)
    Sta-Rite Mod3 60sqft DE Filter (with 8lbs charge) - Sta-Rite 2" Dyna-Wave Pump (<<< L-O-V-E )
    All 2" plumbing (except 3" suction line, modified skimmer) - Two 1.5" returns at 180degrees apart (skimmer return piped down to floor)
    "15' round 5.1K gal AG pool; ~10% liquid Chlorine; Sta-Rite Mod3 60sqft DE Filter DE filter; Sta-Rite 2"" Dyna-Wave Pump pump; 11hrs; Taylor K-2006
    'drops' FAS-DPD Chlorine, ; utility water; summer: ; winter: ; iPhone; PF:24"
    Default Re: Searching for more about "Operating Swiming Pools at High PH"...
    I remember one of Ben's posts in the forum where he said that the high pH pools were not quite as useful as he first thought but I could not find it. I do know the original concept was done by United Chemical who make a line of bromine based pool treatment products that need a higher pH to work properly. Could there be cause and effect here? Hmmm...
    As far as your pool--how are you testing? With results like '100ish' for TA and '7.5ish' for pHI suspect you might be using strips but the bottom line is this, if your pH is rising too fast (and you are NOT dealing with plaster that is less than a year old and therefore not fully cured) then your TA is too high. Period. Lowering your TA will lower the speed of pH rise. Also, when you do add acid do NOT lower the pH too much.
    The lower you place the pH the faster it will rise. Period.
    My suggestion is to drop your TA to around 70 ppm and do not lower the pH below about 7.6 when you do lower it. When it climbs to 8.0 lower it again.
    Hope this helps.
    Jul 2011
    I've got a K-2006. The "-ish" suffix is due to the fact that I've mis-placed my little log sheet that I wrote my very first tests on...and I was going from memory. As for the "PH 8-ish" result at present, the K-2006 doesn't go above 8.0 and although the pink looks the same, it could be a shade higher and I wouldn't be able to reference it. That''s why I '-ish'ed' that number.
    Forgive me, but (on my third re-read of your reply) it seems to me that you are making recommendations for dealing with an undesired PH rise. (which isn't what I'm asking about)
    -or-
    are you suggesting I abandon the whole "run at high PH" (as per the post from Ben that you could not find) and recommending how to come back down to normal levels?
    (and...if this is the case...would it be reasonable to ask Ben to remove that entire 'High PH' webpage...if it is indeed not viable?)
    Your posts has made clear a couple of changes I need to make, on that page, to emphasize or clarify things you are overlooking.
    #1 - I didn't make it explicit, but the high end of that range that I've worked with is 8.2, not higher.
    #2 - At that time, I was using a color block that allowed measurement to 8.2. The Taylor (and most other blocks I've seen) only got to 7.8. You can only go as high as you can measure -- when you try to go higher than that, you have to remember that your readings above, say, 7.8 do not actually mean 7.8 -- they could be 8.0 or 8.5.
    #3 - The most important take-away from that page is NOT "run at high pH", but rather "don't fight your pool if you don't have to do so!" THAT idea is a fundamental element of the BBB Method: if your pool 'wants' to be at 8.1, and you can adjust, do so. But, if your pool 'wants' to be at 7.2, then adjust to that!
    It's still too complex to sum up here, but Chem_Geek has laid out enough analysis to offer a reasonable basis for understanding why some pools 'want' to be at one level and other pools 'want' to be at another. When I wrote that page, I knew that different pools 'wanted' different levels . . . and that they were MUCH easier to operate if you let them 'be' at that level, but I didn't know why.
    Jul 2011
    Ok! I get #3. And I remember reading to "not fight your pool", but I didn't realise the subtle recommendations (on that web page) could relate to whatever level a pool chose to reside at.
    On 1st fill (I never did test my tapwater...), and for a few days, the k2006 showed my pool sitting at 7.5ish (my k2006 block only shows 0.2th divisions...and my water was between 7.4 and 7.6).
    Over the course of a few days I deliberately Boraxed up to 8-ish (my k2006 block goes to 8.0). It's stayed there for a few days since, with no additional chems.
    I don't think I've gotten into the ring with my pool yet...actually this seems to be a pretty easy go... (other than the mystery of my teeny CYA readings, despite having dissolved more than the bottle says to...maybe that stuff is worn out?) However, the reality is that swimming time is pretty much over for us up here..other than the 'indian summmer' I'm hoping for. So far, Ms Irene is beating up on all of us and the coolish grey skies are getting old fast...along with the occasional torrential downpours. I realise next years pool season will be a true test of my preparedness and understanding. I've still got alot to read and learn...
    I'm going to mix in a bit of Muriatic, to just bring my PH back onto scale..and once 'on scale' I'll leave it alone to see what it does...
    Next year will be a clean slate, with proper bather/seasonal loading...hopefully I can leave the 'boxing gloves' in their package...
    OH! (I just re-read my reply here and am reminded of something...) The Taylor kit has a nice little spinny water balance calculator wheel. I remember dialing in my very first readings (which were all within the booklet's spec's) and coming up with -0.4 on the dial. I also remember dialing in readings at PH 8-ish and coming up with almost 0.0. But, does any of this 'really' matter to a vinyl pool? I got the impression the Taylor booklet was leaning towards the commercial side of pools...since it's really made for that segment anyway...and they're all concrete and steel and copper...not plastic or vinyl. I also remember noting that I could have adjusted the -0.4 up to 0.0-ish, if I just increased my hardness...but that seemed pointless to my pool. Then I re-read about the high PH methodology...and realized that would bring me closer to 0.0..along with (what I interpreted) easier/cheaper operating.
    As Ben said, when that post was written the relationship between TA and pH was not as fully understood. Main cause of pH rise in pools (when there is no curing plaster) is outgassing of CO2. Your pool is carbonated much like a bottle of soda. That carbonation comes from the TA (bicarbonate) in the water. The higher the TA the higher the higher the carbonation. The higher the carbonation the faster the outgassing of CO2. The faster the outgassing of CO2 the faster the rise of pH to 8.2 to 8.4. If the TA is lower an equilibrium is reached with atmospheric CO2 at a lower point and the pH tends to stay lower.
    If you are interested in some of the chemisry behind this then this post will explain it.
    FWIW, I run my own pool between 7.8-8.0 (partly because I have 50 ppm borate and the secondary boric acid/borate pH buffer acts in the opposite direction of the carbonic acid/bicarbonate buffer we call TA and keep the pH in that range for an extended period of time.
    The "dial" in your Taylor kit is the Watergram and it is a device for computering the Langelier Saturation index, which is one of the calcium saturation indices used for pools. It really is not useful for a vinyl pool. and is often wrongly applied to other surface pools. It can be used to predict scaling conditions BUT the main factor in the mathematical equation behing it is pH SO (drumroll please) HIGH Ph IS THE MAIN FACTOR IN ANY POOL THAT PREDICTS SCALING CONDITONS!. As far as aggresive water conditions, the Langelier Saturation index CANNOT predict whether water will be corrosive to metals at all. It can predict whether water can be aggressive to a plaster finished pool but, once again, the MAIN faster here would be LOW pH (which is usually only a problem on pool runs on either trichlor or dichlor).
    In other words, you can play with it but it means nothing to your vinyl pool. Your pH is what is important and your TA is what determines how fast your pH will rise.
    Also, a few fun facts about high pH pools. Like I said, it was developed by United Chemical several years bck and they sell a whole line of bromine based pool additives that require a high pool pH AND when it was being recommended most people were trying to force the pH down to about 7.2 or 7.4 and did not understand the roll that TA plays in pH. The misconception (still taught by many in the industry even today) is that higher TA will stabilize pH. Nothing is further from the truth and people found themselves battling high pH and even trying to raise their TA to combat the high pH when in reality they were making the situation worse!
    Just so.
    I had discovered, as a result installing an ORP-pH controller on some spas at the Hyatt in Atlanta that aeration + pH control would eliminate carbonate alkalinity in 15 minutes. I repeated the process 3x, because it violated everything I'd been taught, and I was still 'drinking the pool industry's kool-ade' at that point. (I'd just become a CPO instructor the year before, and hadn't yet found all the errors in the CPO exams!)
    And, I'd also discovered that many of the problems reported when people tried to run commercial pools on bleach disappeared when you let the pH drift up to 7.8 - 7.9. It was this, and some related experiences, that led me to began to understand that many of the difficulties people had with pools were artificially generated by the pool industry's focus on a set of arbitrary numbers.
    I didn't yet know how pH related to the HOCl/-OCl chlorine curves published everywhere,
    (from Santa Barbara Controls, an ORP/pH controller mfg)
    but I knew that it once you added CYA, it wasn't what was being shown. Now, of course, Richard (Chem_Geek) has used Wojotowicz's and prior work to create this one:
    When I was looking for an example chart to link, I found this unintentionally funny post on poolspaforum:
    http://www.poolspaforum.com/forum/in...howtopic=19260
    where someone in the pool industry offers to help Chem_Geek to take some of the industry training classes, so he could understand that standard, and very wrong, curve better. What's funny is that, by the time of that post (2009), Chem_Geek knew more about overall analytical pool chemistry than anyone I've every known in the pool business. There were (and probably still are) some PhD chemists in the biz, but all the ones I've talked to are so lost in the 'trees' that they don't even KNOW that there is a 'forest', so they know more of some of the details than Richard does, but still don't understand pool chemistry as a whole.
