Cloudy Water from algae
So I have this above ground pool that was drained and the liner was replaced. It was filled back up then it started to rain and continued to rain for about 2 weeks non stop. The pool developed a lot of algae, the pool turned a dark green color. I added a bunch of granular pool shock after the rain finally let up. The pool turned turned from a dark green into a light green. Now it's a blue color but very cloudy. I added some flock, then came back the following day and I could see the bottom. So I vacuumed the pool and as I was vacuuming I could see clouds coming out of the 2 returns. So what I was vacuuming is just going right back into the pool. After I was done vaccuming I cleaned out the cartridge filter. The pool is still cloudy and I am not sure what to do. I can't seem to get rid of the cloudiness. If I flock the pool again and vacuum, the dead algae (I assume) will just get right back into the pool. I can't stand cartridge filters!!!
7k gallon above ground liner pool
A single cartridge filter
Fc 2
Tc 2
PH 7.5
TA 95
CH 50
CYA 20
Crystal Clear Pool Service, LLC
