Results 11 to 12 of 12
Thread: Pump troubleshooting
    BigDave's Avatar
    Default Re: Pump troubleshooting
    The change over time may be attributable to normal wear and tear if you've been using the same extension cable. Cable insulation can breakdown over time due to exposure and heat. Heat increases resistance in cable. Resistance lowers voltage. AC motors spin at a fixed speed and will use as much power as necessary to keep that speed. so... as cable heats up, resistance goes up, voltage goes down, as voltage goes down, current (Amps) goes up because Volts * Amps = Watts (Power) and power is fixed.
    As Ben points out, low voltage will kill your motor this is because the windings are sized for a certain amount of current when current goes up the windings overheat and ... time for a new motor. Ben's right that a larger extension cord may help, 12/3 may not be enough depending on length (resistance is also a function of length). Be aware, 10 guage cords are very expensive.
    SW Missouri
    Did you have the motor capacitor checked?? I would assume that was done with the other work.
    Interesting problem!
    20,000 Gallon IG Vinyl (first season 2000)
    Solar Heat
    2 Speed Rebuilt pump
    Sand filter
    cooldude.com/pool-1.jpg
  1. Light Fixture Troubleshooting
    By wingsfan in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2012, 12:03 AM
  2. Pool Light Troubleshooting
    By seasonal in forum Pool Equipment & Operations
    Last Post: 09-19-2011, 12:08 AM
  3. Troubleshooting a Hayward navigator....
    By chrisexv6 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-13-2007, 04:35 PM
  4. Gas Pool Heater Troubleshooting
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 08-02-2006, 05:53 PM
  5. Need help troubleshooting pump; won't spin
    By madgame8 in forum Pool Equipment & Operations
    Last Post: 04-02-2006, 08:43 AM
