Pool Pilot Digital: Check/Clean Cell Message
I have a Pool Pilot Digital running at power level 2 with an SC-36 cell. I replaced the cell at the beginning of this season, as it had gone over 10,000 hours and was no longer producing chlorine.
I am currently getting the Check/Clean Cell Message whenever the salt generator is ON. The salt level is 3200. The water temp is 83 degrees. The cell is clean. Volts: 17 Amps: 4.2
The system is actually working fine, but I cannot get rid of this warning. It seems like the vols are OK, but the amps are low. Any idea how I can correct this?
Thanks, Bill Howland
