Results 1 to 3 of 3
Thread: Anyone heard of The PoolCleaner?
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Default Anyone heard of The PoolCleaner?
    As I posted below, one of the recommendations to reduce energy costs in my system is to switch to a different cleaner called The PoolCleaner. It can be seen at http://www.thepoolcleaner.com/index.html
    It is a suction-side cleaner that runs off of even a lower-speed pump, allowing me to run a variable speed pump on a lower setting and still clean the pool. I tried it for a few days and loaded the pool with everything that was in my Polaris bag plus some twigs and such from the yard (to simulate debris from a winter storm). It worked pretty well, and would definitely save on energy costs, but I am wondering if anyone has seen these.
    I would use my current pressure-side sweep line and replumb it for suction-side use while some other plumbing gets optimized/repaired.
    Salinda
    owner of ~35,000 gallon plaster IG pool/spa combo. Ikeric Dyna-Miser VS150 filter pump, 2 hp whisperflo spa jet pump, The Pool Cleaner 2x suction cleaner, Clean & Clear Plus 520 cartridge filter, Zodiac Clearwater LM2-40 SWG, Sta-rite 400k heater, solar heat pads and coils.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Anyone heard of The PoolCleaner?
    I have the suction side 2x cleaner and it seems to work pretty well although I have nothing to compare it to. It is my first and only cleaner that I have used.
    However, I am in the process of selling mine and upgrading to a robotic so I can run it at night when no one is swimming. Check your messages, I sent you a PM.
    Mark
    Sacramento, CA, USA.
    I have sold or installed many of these cleaners, first when they were marketed by Jacuzzi and now by the original manufacturer. Never had a complaint, not one.
  1. Anyone ever heard of milliniad pools?
    By Pocono Mark in forum Above-Ground Pool Construction & Repair
    Last Post: 07-10-2011, 11:34 PM
  2. Has anyone heard of a Siverado Pool?
    By Stonedbeetle in forum Above-Ground Pool Construction & Repair
    Last Post: 04-23-2011, 06:00 PM
  3. Have you heard of the Nitro Robotic?
    By ryguy in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-19-2008, 01:34 AM
  4. Anybody heard of Aquachlor???
    By cmack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-28-2007, 04:00 AM
  5. Anybody heard of/done business with...
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2006, 12:28 AM
