Thread: Opening numbers
    duraleigh Guest
    Default Re: Opening numbers
    Hi, Boyd,
    Wow! We finally got a nice name for poolidiot! (which you never were)
    I'd do just like you're thinking.....Cl up to shock level, test, and if numbers are good, I'd backwash the sand filter one last time and then put the CYA in.
    Dosage for CYA is on the container or you can get mwsmith2's calc and figure it yourself.
    Whatever you did last Fall, I'd do again this Fall
    mbar's Avatar
    Ashland, PA
    I agree! I seem to lose my cya over the winter all the time. I know some others do to.
    Northeast PA
