Results 1 to 8 of 8
Thread: The Sun
    Default Re: The Sun
    Was your question answered? -Ben
    Aug 2011
    22k antique in-ground pool, SGS SG 3000 SWCG, tw
    Default Re: The Sun
    Yes, Ben - thanks! Think the thing that had been causing me the most trouble was understanding how & when chlorine bound up with CYA was released and became available. Sheltering it is all well and good, but unless there was some way for it to come out from that shelter, I was always hazy on what benefit it had.
    Now, in a side question -- at what point does the sheltered chlorine become noticeable / unpleasant for humans? With constant recharging via SWCG, is there a ceiling to CYA levels where keeping things that high becomes a bad idea?
    Default Re: The Sun
    Read through the "Best Guess" page (in my signature), which addresses this topic at some length. If you still have a questions, after, ask again.
    Ben
    Default Re: The Sun
    Also, most SWCG's recommend a maximum CYA of 80 or 100 ppm and in actual practice running the CYA at the maximim is better than running it at lower levels. I will explain more below.
    Quote Originally Posted by Interloper View Post
    What this really seems to mean, to me, is that I don't really need to do anything once I find the power setting on my SWCG which seems to be able to burn off chloramines. Accidental super-chlorination won't be a problem, because Mr. Sun will simply burn off any excess. If I ever want to really "shock" the pool, I'd just dump in a couple gallons of bleach at dusk, just as I did back in my BBB days.
    There is so much wrong with that statement that I don't know where to start so I am going to just ramble on below and hope it explains it all! However, I will say this--the proper FC level to maintain is 5% of the recommened manufacturer's maximum CYA level and the CYA should be kept at the mamimum for an outdoor pool. This translates into 4 ppm FC and 80 ppm CYA for the majority of US made SWCGs and 5 ppm FC and 100 ppm CYA for many of the Australian made SWCGs. This is an empirical observation but it has proven true for several years now by members of this and some other pool forums on the internet and has been sufficiently proven to me by my own observations in the (admittedly limited) number of customer's pools with SWCGs (and in my own).
    Could be I just don't get it -- but it sure seems like a SWCG becomes a sort of self-regulating device. Like using a brick as cruise control because your car has a regulator set at 55 miles per hour.
    As far as why test water with a SWCG, the SWCG is only an autmated way to add chlorine to the water. The amount of chlorine present is adjusted by adjusting the cell output and/or pump run time. IF you have a unit with automatic ORP control of sanitizer level (THIS would be the regulator set at 55 MPH you mention) then you do not need to test FC as often (but electronic controllers are only as good as their calibration, which can and does drift, and they do fail after a period of time and present their own set of maintenace tasks that are more complex, IMHO, than testing and tracking chlorine levels!) If you do not have an ORP controller and electrode then the unit is 'dumb' and just makes chlorine for whatever percentage of pump run time you set it for. It is entirely possible for the FC to be too high or too low. However, once you get it adjusted right it can be pretty stable. I only need to adjust my cell output/ pump run time in the spring and fall (my pool is open year round) since the hotter summer requires more cell on time than the cooler winter to maintain the same FC in my pool.
    However, if you have a week or two or rainy weather or have a pool part with a huge bather load then you might need to manually shock the pool, just as you would ANY pool or maybe make some adjustments to run time or cell output before hand if you know the pool party will have 40 people in a 10K pool and you want to start with a higher FC level and maintain it a bit higher for the party to 'keep up', just like in any pool.
    You still need to do regular testing of pH, TA, CH, CYA, and Salt (particularly if you have a backwashing sand or DE filter or the pool has an autofill device). The SWCG does not automate other water balance issues (with the possible exception of those units that come with add on pH controller/electrode and use either CO2 gas injection or acid feed using a peristaltic dosing pump for pH control. However, once again these have their own set of calibration/maintenance issues and, from my experience using automated pH control on commercial pools I can tell you it is MUCH easer to test pH and dose the proper amount of acid to adjust pH downward than to get these type of units calibrated and adjusted. If your test kit has an acid demand test this becomes even easier (even though the genera feeling on the forum is that acid demand tests are not useful). If the concern is overdosing on acid becasue of bad testing technique using a demand test, well, I really cannot comment other then to say work on your testing techniquie, it ain't rocket science! Also, just because you have pH automatin does not mean that you don't have to test pH. Testing the pH is the ONLY way to know if the controller is operating properly and if it is not then you need to take corrective action manually and then readjust/recalibrate/repair the pH system!
    While the SWCG does automate the addition of chlorine it does add a unique problem with pH control since the constant aeration of the water caused by hydrogen generation at the cell cathode will cause CO2 to outgas faster which leads to the pH rise problem so often seen with salt pools (It is NOT, as often stated, due to the formation of sodium hydroxide since the excess OH- ions are neutalized when the chlorine is reduced back into chloride ions in the process of sanitation/oxidation, an acidic process).
    The pH rise in salt pools (or any pools, for that matter, that use an unstabilized chlorine source like sodium hypochlorite--which is what the SWCG produces, calcium hypochlorite, or lithium hypochlorite is primarily from the outgassing of CO2! (We are ignoring any effects from new, curing plaster or aggregate finishes since they are a transitory cause of pH rise in pools.)
    There are a few things a pool owner with a SWCG can do to minimize this:
    1. Run the CYA at the manufacturer's MAXIMUM level so the cell on time for the desired FC level is as short at possible. This will minimize areation and therefore pH rise.
    2. Maintain the FC at 5% of the CYA Much empirical evidence suggests that this is the 'sweet spot' for minimizing algae outbreaks, chloramine production, etc. (Thanks chem geek!)
    3. Maintain the TA at 70-80 ppm (and adjust the calcium upward for a plaster or aggregate finish pool if needed to maintain proper water balance). TA is actually a measure of the amount of bicarbonate in the water and the higher the bicarbonate the more CO2 can form. The more CO2 in the water the faster it will outgas, the faster it will outgas the faster the pH rise. This is to our advantage when we are using stabilized chlorine sources like trichlor and, to a lesser extent dichlor, bromine, and MPS, which are both net acidic on use and need to have the constant acid additions neutralized but it works against us with any of the unstabilized chlorine sources and SWCGs which are pH neutral on use (alkaline on being added or created in the pool, acidic on santizing/oxidizing.
    Lower TA mean less bicarbonate in the water means less carbonic acid means slower ougassing means slower pH rise.
    4. DO NOT DROP THE PH TOO LOW when lowering pH. The lower you put the pH the faster it rises because the lower you put the pH the more bicarbonate you convert into CO2/carbonic acid (operative word here is acid). The more CO2 the faster it will outgas, The faster it tougasses the faster the pH rises. We use this fact to our advantage when we are trying to lower TA by dropping the pH to the lowest save limit to drop the TA (by converting bicarbonate into carbonic acid/CO2) and by then aerating the water to drive off the CO2 (reducing the amount of carbonic acid and causing the pH to rise quickly.
    IF we do not drop the pH in a salt pool below about 7.6 and lower it when the pH hits 8.0 we will find that we have a more stable pH for a longer time than if we drop it to a lower value when we add acid.
    5. Add borate to 50 ppm. Besides the well documented algaestatic properties of borate it also introduces a secondary borate/boric acid pH bufffer that works in a complimentary way with the bicarbonate/carbonic acid buffer already in the pool. The bicarbonate buffer tends to push the pH upward toward 8.4 while the borate buffer moves the pH downward. Together they keep the pH at around 7.7-7.8 for an extended period of time. Borates can be added inexpensively with 20 mule team borax (sodium tetraborate decahydrate) and muriatic acid or you can use straight boric acid or one of the proprietary borate products (which are either sodium tetraborate pentahydrate or a mixture of mostly boric acid and some sodium tetraborate pentahydrate) from Proteam, Bioguard, Guardex/Omni, or Pool Life (HTH). There is a lot of info already in the forum about using borate and if you have any questions you can always start another thread.
    Hope this clears some things up.
    Ben, at your discretion, move this to the China shop if you see fit! However, it is just general SWCG advice with the explanation as to why.
    Default Re: The Sun
    Also, just because you have pH automation does not mean that you don't have to test pH. Testing the pH is the ONLY way to know if the controller is operating properly and if it is not then you need to take corrective action manually and then readjust/recalibrate/repair the pH system!
    Yes.
    This is one of the MAJOR reasons I dislike ORP/pH control systems -- and I was a dealer for a $6,000 set up for years. Calibration is complex, compared to other pool tasks. And it is ESSENTIAL!
    I have seen a brand new therapy center DESTROYED over one weekend by a new and mis-calibrated ORP/pH controller and acid feed system (not my installation - I was hired as a post-disaster consultant). Damage exceeded $200,000.
    If you over dose acid by hand, you have a little problem. If your pH controller fails, due to poor calibration or for any of a number of other reasons . . . and you have a fresh tank of acid, you can destroy your pool!
